1965 cruiser front end alignment
  • 1965 cruiser front end alignment
    I am FINALLY getting my 65 cruiser back on the road after being sick for a couple years. My question is does anyone know the correct wheel alignment specs for a 1965 cruiser 283 c.i. auto trans no a/c w/ power steering? I have a manual somewhere, but can't locate it!
    Thanks in advance to all, and happy Studebakering!!!!
    Roger Corriveau
    Portsmouth, NH
    Tri -Spokes Chapter Member
    Roger Corriveau
    should be the same as a '64 I would think
    specs for '64
    toe in 3/16" to 1/4" w/o PS, 1/16" to 1/8" with
    caster (at curb load) +1/4 degree to -1-1/4 degree (no more than 1/2 degree variation)
    camber 0 to +1 degree, 1/2 degree more favored on driver's side
    HTH
    62 Daytona hardtop
        thank you so much for the replies....you guys are great!!!
        Roger
        Roger Corriveau
          Roger:
          Go ahead and set the toe as specified. However, if you are running radial tires and it drives funny, reset the toe to ZERO toe-in/toe-out.BP
          BP
          Ayn Rand:
            It might be worth remembering that most front ends "Toe-Out" at speed and should therefore be set with a little toe-in when stationary (this includes radial tyres).
            Another often overlooked point : Drive the car slowly in a straight line onto the wheel alignment hoist (ideally 2 - 3 car lengths). Do not allow someone to "corner" onto to the hoist, it puts stresses into suspension bushes, which "release" when you later drive straight ahead.
            / Hank
