carb problems
  • carb problems
    well my 50 champ has carb problems
    still gots the six with rockchester 1 barrel
    when you rev it off an idle it stumbles at first then it gets with the pace (all the time weather its hot or cold)
    my educated guess is that the accelerator pump is either bad or going bad
    also the when i try to start the car after sitting for at least a day it takes forever for it to get gas to the carb to make it fire and start ( almost so long it runs batt way dwn )
    another thing when i look dwn the carb with a light and pump the gas i can not see it squirting. seems to me like i should be able to
    wonderin whats causing these probs? like i said my guess is accelerator pump
    any ideas were i could buy a carb repair kit that is an exact fit
    i called some repair shops and they want like 100- 150 dollars to repair
    im just not gonna pay that much for something thats coming out in at least a years time
    Sounds like the pump, buy a kit from a Studebaker vendor for around $25 and you'll be good to go.
    64 Challenger (Green Wrapper)
    63 R2 4 speed GT Hawk
    55 Speedster
    50 2R 10 truck
    JDP Maryland
      test
        r u saying acccelerator pump or fuel pump JDP
          oh yeah its not a rochester its a carter
            doesn't matter, if your FLAPS doesn't have a kit, a vendor will. When you install the new accel pump put some engine oil or neatsfoot oil on the leather and flex it out a little bit. If the carb runs well otherwise you should be good to go. If you are real cheap you can try to just oil the accel pump but make sure the carb doesn't leak when you put the top back on (since you're reusing an old gasket)
            good luck,
            62 Daytona hardtop
