Detroit Gear Trans Fluid
  • Detroit Gear Trans Fluid
    Shop manual recommends 10 weight motor oil for DG-200 transmissions. What fluid do you run in your tranny--stick with the original, or 'upgrade' to modern fluid--if so, which type[?]
    Use Dexron-Mercon III Just be sure you drain the torque convertor when you drain the pan, so as to get ALL the old oil out.
