ok ive heard rumors that if the overdrive is engaged that when the car is not running and in gear it will roll without touching the clutch (freewheel)
is this correct and will it do the same in any gear
my 50 champ , if in 1st will roll but if you stick it in reverse it wont
now is my over drive engaged or not
i recently painted all my dash and surrounding interior parts as well as rewired the whole car but i have yet to attempt to wire the overedrive or evan drive it at a speed that would allow it to shift into od. all the original wirring is there and in the car for the overdrive except its falling apart . well to make a long story short i havent evan messed with my od so i really dont know what it is or isnt suppose to do
also what kinda chances do i stand that it still works . the car is in fairly good shape and everything else worked its just i didnt trust all the old frayed wiring so it all got rewired
one more thing if it does work will it funtion on 12 volts if not how do i make it work on 12 volts
some help and guidence from the gurus would be apprectiated
thanks gotti
thanks gotti
