1963 Champ
This topic is closed.
  • Transtar60
    Well your getting warm. That is a Studebaker V8 head #.
    On the center front of the engine, just above the timing cover, should be a little flat blockoff plate held on with two bolts. Just to the right of that(as you are standing in front of the truck) should be a flat machined spot where the serial # should be Stamped. Like one of the previous posters said, they are not big letters, 1/4" or 3/16 " maybe
  • KevinSheen
    Okay folks, I found the number 1557570 cast on the cylinder head center exhaust port. I also found the number 1554341 on the radiator. I think we are getting closer. Any way to cross reference these numbers to an engine type? Thanks. Kevin
    1963 Champ
  • KevinSheen
    Thanks Whacker, I'll check it out. Kevin
    quote:Originally posted by whacker
    For answers to your engine serial number questions, might I suggest:
    http://www.studebakerdriversclub.com/tech_v8data.asp
    This is right here on this web site under the tech tips and specification section from the home page. If the serial number is not where MrBiggs suggested, the only other place might be at the opposite corner, to the left (as you face the engine) of the distributor. This would be a long shot, as that serial number would be a 5-6 digit number, and would specify a 232 engine from 1951 - 1954. That would have to have replaced the original sometime in the past. A long shot as I say. If the serial starts with a cloverleaf, or is only a cloverleaf, the engine is a factory replacement engine.
    1963 Champ
  • whacker
  • KevinSheen
    Hey Jean, So far I haven't found any numbers on the engine. It also doesn't say International on it. All I know is that its yellow. Found the ignition problem too. Needs a new solenoid and I'm good to go. Fortunately, the solenoid that's there already is a regular Ford part and easily replaceable. So I'm having the guy check out the brakes in the morning and I'll be cruising. Happy Days Kevin
    quote:Originally posted by mjeansonne
    Transtar;
    Of course, you're right about separate prefixes for engines in cars and trucks, but as I said, "my memory ain't what it used to be"!!!!
    BTW Kevin, I've had people argue with me that Studebaker trucks were built by International! Maybe that's where the '345' is coming from.
    Laisez le bon temps roulez avec un Studebaker
    1963 Champ
  • mjeansonne
    Transtar;
  • KevinSheen
    Good deal, I'll look and let you know what I find when I get the truck back. I hope like hell its the original engine. KS
    Kev,
    The engine serial# (which should shed light on what displacement it is and what it might have originated in - car or truck) is stamped (not "embossed" or "cast") onto a flat area, right at the front of the engine block itself. Right where the driver's side cylinder head meets the front top surface of the block - scrape away any grunge there and look for a stamped number. Likely it starts with 3E, 5E, 6E or 7E if it started life in a truck. If it started life in a car, a V or a P would likely be the first digit.[:I]
    They're not BIG digits. They're only about 3/16ths an inch tall if that much.
    Thanks for noting the signature. I try to be a nice guy. But it's easier when you set low expectations to start with![}]
    Miscreant at large.
    1963 Champ
  • Roscomacaw
    Kev,
    Miscreant at large.
  • KevinSheen
    Thanks for the info Mr Biggs. The valve covers dont have any named on them. So that's a good sign. There is also no number embossed on it that I could find with just a cursory look. The only thing I've found so far is the firing order. I've got the truck in a local shop right now. Hopefully they can fix the ignition problem without too much difficulty. I'll then have a better look around to see if I can find any identifying marks. Thanks for the feedback.
    BTW, my wife and I really like your signature. I was thinking of changing mine to reprobate. Kevin Sheen
    I can't imagine anyone going to the trouble to put a 345 in there, but I suppose anything's possible. From what I remember - if it's an International 345, it will have "International" embossed along the length of the valve cover. The Stude engines don't have their name embossed onto the valve covers. They MIGHT have a decal but it wouldn't be "factory" for a Champ to have any such decal. If there was a decal, it would be because some owner chose to put one on.
    If the vavle covers are held on with 2 or 4 nuts down the center of the cover, it's likely a Stude engine.
    Miscreant at large.
    1963 Champ
  • Roscomacaw
    Miscreant at large.
  • KevinSheen
    Thanks again Transtar. I don't have any manuals yet but I will be getting one in the near future. I am a novice at this, but I'm hooked. My poor wife thinks I've lost my mind! Thanks again for your help. Kevin
    1963 Champ
  • Transtar60
    Kevin and Mjeansonne.
    Truck engines have their own numbering system.
    If its a 259, the starting # for 1963 Standard duty 259 cid engines was 3E 18,901 If its a heavy duty 259, the number will start with "5E".
    Standard duty 289's serial #'s started with 7E and heavy duty 289's with 6E .
    The serial # ranges for trucks are listed on page No. VII of the parts manual. If you dont have a parts and shop manual yet, I highly recommend you get some from one of the vendors. They really make buying parts and working on the truck easier .
  • KevinSheen
    Thanks again for the info. I was trying to figure out how to find out the size of the engine. I hope its not a replacement that's in there. I've got your e-mail address in my book now. Mine is kls1040@cox-internet.com. You are, of course welcome to come by if you're in the area and have a closeup gander at the truck. I'm on vacation for about another month. My regular job is merchant seaman so, when I leave I'm usually gone for 6 months or so. Then when I'm off I've usually got a couple months before going back to a ship. That's why I drive a truck when I'm off.
    Looking forward to meeting you too. Kevin
    1963 Champ
  • mjeansonne
    As I said, thats one heck of a good looking truck you have. Of course, I'm partial to Champs. Mine is red. The engine blew a not long ago and I am in the process of also replacing the engine. Its a 259 cid V-8. In 1963 Studebaker only had two choices of V-8... 259 cid and 289 cid. Both were proprietary (built by Studebaker) and were not built by anyone else other than Studebaker! Yours is probably a 259. Standing in front of the engine, look down just to the right of the top radiator hose on the engine. There is a pad with a number preceded with a letter, either a 'P' or a 'V'. Depending on which letter precedes the numbers, will determine what size engine you have, 259 or 289. I will have to go downstairs to where my books are to tell you which letter equals what. My memory ain't what it used to be and I can't recall suddenly which is which!!
    Incidently, my e-mail address is: mjeansonne@Sport.rr.com that's here in Shreveport where I work during the week. I go home on the weekend. I sometime go to Pine Prairie on the weekend for boudin, ponce and cracklin. Crowley ain't far. Sure would like to take a close up of your truck sometime.
    Laisez le bon temps avec un Studebaker
  • KevinSheen
    That was me you saw. I bought the truck in Wichita, KS on Saturday afternoon. Spent the night in OK after having a blowout about 50 miles after I bought the thing. Passed Alec about 7 PM and was in Lafayette before nine.
    The Champ is in pretty good shape, but will need some TLC of course. Some of the paint is chipped and/or peeling. I don't think it was a very good prep job.
    I talked to Fred D. today about joining the local SDC. I'm waiting for an e-mail from him. Any how looking forward to meeting you as well. What do you think about the engine size being a 345 ci?
    I know exactly where Boyce is. I drive an 18 wheeler (part time) full of propane to places like Herring gas in Trout.
    Thanks for the info. I'm relieved to see that great minds think alike! Kevin
    1963 Champ
