rear ends
  • rear ends
    I just picked up a 57 Hawk to restore. It needs a new rear end. Does anyone know of any rear ends that would bolt right on to the leaf spring perches and be about the right width?
    I don't believe there is anything that will "bolt right up".
    Any Studebaker car rear end from '53-66 will, however, bolt right up. They are plentiful and relatively inexpensive (many times free).
    What are the indications that it needs a new rear end? Perhaps fixing the existing one would be the easiest way out. It is a Dana rear end and parts are readily available.
    Bellingham, WA
      Thanks Dick, I saw a post from another guy with a similar question and discovered your Stude has a 327 and 4 speed. Thats what the one I bought has. (It was an old timers hot rod) I plan on redoing it with the same drive train.Soooooooo, if the Dana44 is good for you, it's good for me!
      Thanks again!
        Mine is the stock Dana 44 that has been with the car since new. I've put over 30,000 miles on the car since I built it...including some fairly hard use...
        http://www.videoegg.com/video/bnCEyB
        I am in the process of upgrading the axles to the Fariborn flanged ones, however. Not because anything has failed...I personally just feel safer with the flanged one.
        Bellingham, WA
          Anything you might order.
          I ordered a Winters, Quick Change for my Conestoga.
          Make sure you give the right dimensions for any given company to build to, and it should bolt right in.
