Power Brakes Question 63 Lark
  • Power Brakes Question 63 Lark
    I'm going to be converting our 63 Lark 2dor sedan to power brakesm this spring. I've got the Master-Vac Booster located, and is there some sort of additional vacuum resevoir tank that I am goin to need or does that Vacuum resevoir refer to the actual Power brake booster vacuum cylinder. Any help would be very much appreciated as I want to be sure I have all my parts lined up ahead of time. Thank you...Waydon
    There's no "vacuum resevoir" as you suspect. There's only the booster. It gets it's vacuum directly from the intake manifold. So - one less part you have to track down!
    Miscreant adrift in
    the BerStuda Triangle
      Do you have the shop manual for this car? If you don't, they are available from Studebaker International or SASCO.
      In Group II is the section on the brake system. The description on page 29, covers the Master Vac system pretty well. It's an independent system. Yours would be the suspended system.
      97 North 150 West
      Greenfield, IN 46140-8562
      317-462-3124 FAX: 317-462-8891
      Studebaker Autoparts Sales Corp (SASCO)
      410 W Sample St.
      South Bend, IN 46601
      574-287-3381 800-722-4295 or FAX:574-287-3386
      These are by no means the only suppliers available for catalogues or service manuals. You might want to shop around and look into e-bay as well.
      Good luck. That's a nice Lark.[:X][8D] I really like the '63s
      Lotsa Larks!
      Ron Smith
      Home of the famous Mr. Ed!
      Ron Smith
        Thank you very much for your advice, it was very much appreciated...Waydon, Wayne Perry
