Bearing Help
  • Bearing Help
    I bought these bearings off eBay. When I opened them up, this is what I found. I emailed the vendor, and he says the oxidation is on the back sides of the shells, and should easily come off with steel wool or sand paper. I am not sure I want to even try.
    Would you use these?
    Paul
    Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
    Paul
    Winston-Salem, NC
    I don't see any problem as long as the bearing surface is okay. I would use steel wool on them as it is less abrasive.
    David
      Inner surface is critical, edges and outer surface should be cleaned. What is application?
      Brad Johnson
      33 Rockne 10
      51 Commander Starlight
      53 Commander Starlight
        Brad Johnson
        Stude V8........
        Paul
        Paul
        Winston-Salem, NC
          Well....if they were mine...I "definatly" send'em back.
          Being that there is the same steel backing under all of those coatings of copper, lead, babbit, what ever all is used...you have no idea how far the corrosion on the steel has progressed. It WILL eat right under the soft bearing material and you won't know it untill the engine is loaded a little and chuncks of bearinf material breaks off.............!
          Send'em back, [u]do not use them</u>, that's my two cents worth.
            I agree with Mike It's to much work If those bearings fail, and could cause damage to crankshaft and other engine parts![8D]
              If it's a set in a size I can use and the price is fair, I'll buy them. the back surface will clean up with some oil and a Scotch Brite pan.
              Studebaker On The Net
              http://stude.com
              Studebaker News Group
              Arnold Md.
              64 Daytona HT
              63 R2 4 speed GT Hawk
              63 GT Hawk
              63 Avanti R1/AC
              63 Avanti R2/4 speed
              63 Daytona HT
              63 Lark 2 dr.
              62 Lark 2 door
              62 GT(parts car)
              60 Lark convert
              60 Hawk
              52 Starliner
              51 Commander
              JDP Maryland
                Ditto on Mike's reply...If the vendor dosen't see a "problem" with them, let him use them in HIS engine..IMO
                Dan
                  What gets me is people selling these parts should clean these parts up before selling and they would have a better idea of the condition of the parts and their value! They might even get more money!
                    Hard to say how they would clean up just by looking at a picture, but they're probably not usable. Certainly not in an engine you plan to use a lot or run hard. If they are not a good quality tri-metal bearing to start with, I wouldn't want them anyway.
                    In cleaning, you cannot remove any material, yet any surface imperfection left behind on the backside will transfer to the bearing surface when the caps are torqued down. Bearing failure is then almost certain.
                    Dwain G.
                      Yea....cleaning a rusted bearing to sell as good parts........that's like putting a bandaid on a leg amputation........more damage to follow!!
                      Some don't seem to understand the way corrosion works. It doesn't matter (for the most part!) what's covering the base metal...the corrosion WILL continue it's propagation right around and UNDER "most" coatings. And bearing material is NOT a rust proofing material!
                        Rust is metal. Once it gets into the oil, it will go through the entire engine. The abrasive metal will cause early wear and you'll be back into that engine before you know it. Last I checked, new repro mains were still $75.00 a set + shipping. It isn't worth taking the chance for that price.
                          These are RODS, they are only $50.00, but they will be like the $75.00 Mains, just cheap imports. [xx(] Good USA Federal Mogual bearings are a little more than double that! [^]
                          Studebakers Northwest
                          Ferndale, WA
                            If you go to the trouble of pulling the engine apart, get pristine and perfect bearing shells. Crank bearing failures can be pretty spectacular and they are always expensive to fix.
                            I sure wouldn't fit in any of my engines.
                            /H
