Will they fit?
  • Will they fit?
    Will these wire rims fit a 64 Cruiser? I'm getting new tires and just happened to see these also.
    http://store.cokertire.com/wire-whee...tyle-wire.html
    if the bolt pattern is 5 on 4.5" and the offset is about right, then yes.
      If the offset is correct, yes.
      You have to tell them the position you want the rim vs. the hub. They can pick a rim to fit to make up the full wheel to fit most applications.
      Just measure your wheel...where the wheel contacts the hub...to where the rim is in relation to that point.
      They should be able to make up whay you need.
      They can makeup most any positive or negitive offset, they just need to know what you need.
