Car on blocks...
  • Car on blocks...
    Well, the '40 is now up on blocks. I pulled the wheels off and am going to get them sand blaseted, painted, then get new tires. I think I will go with a whide white wall style, and radial. Probably a set of Diamondbacks. Has anybody tried these, and how do they compare to Cokers[?] Just looking for some tire opinions here. Thanks.
    *Sorry, no red rims!
    Chris Dresbach
    1940 Champion two door.
    Parts of the 1952 Model N
    1960s Prototype cart
    Chris Dresbach
    No red rims! How about GREEN!
    Alex Nelsen, 15 year old Studebaker nut.
    1954 Champion Coupe
    Lizella, GA
    Lizella, GA
      the '40 is now up on blocks. I hope the blocks are solid wood, or better yet, jack stands, the cast iron type, not the formed steel tube type. We don't want to loose you yet, Chris. I remember holding up a '36 Ford, once, with my left shoulder. I was lucky, the gas tank was soft and the ground under me was soft. It took 3 years for my sternum to stop hurting.
      Tom Bredehoft
      ....On the road, again....
      '05 Legacy Ltd Wagon
      All Indiana built cars
        Diamondback tires are excellent so I believe. They also use tires from the original manufacturers not those made from old worn out molds the OEM has sold.
        John Clements
        Avantilover, your South Australian Studebaker lover!!!
        Lockleys South Australia
        John Clements
        Christchurch, New Zealand
          Chris did you get a copy of the Prodction Order on your car? Sounds like you want to keep it original so that may be a good guide to follow on the restoration. Everyone will probalby have different opinions on tires but I like to stay with an original look and have driven many good miles on Bias-Ply tires in lots of different conditions. Good Luck! with your car no matter what direction you take. Ed
            The blocks are wood. There used to be a big wooden barn that fell down in the yard where I'm working on it, so some of the main support beams were cut up into blocks, so I just used four of them. I do have the production order. The car has an odd history, built in SB, sold in Des Moins, to Indy, then to Nashville In; then back to SB![:0] I plan on restoring it back to origional condition, as best as I can. No hot rods/rat rods/modifides/gassers/A-FXs here![8D][^] I think I will probably go with radials though, just because I want to drive it, a lot.[8]
            Chris Dresbach
            Chris Dresbach
              Cokers??!?? Better rob a bank!
                Diamondbacks it is...[:0][8D]
                Chris Dresbach
                Chris Dresbach
