Rod bearing question
  • Rod bearing question
    I'm taking apart the engine that came with the 62 Hardtop that I just sold. Number 3 cylinders rod bearing was spun and part of it is missing. The rest of the bearings were thin and scored pretty good, mains weren't thin, but did have a lot of scoring. The back of the rod bearings are marked with p/n 1555187 with the letter B below the p/n. I looked in the chassis parts catalog and cannot locate that part number in the bearings. Is anyone familiar with what size it is? The engine is a 62 partial flow block. I figure I'll have this one rebuilt and eventually a car missing an engine will make itself known.
    Dare to be different... Drive your Studebaker!!
    Assuming you're going to send the crank out to be checked, ground and polished in which case the rebuilder would either supply proper sized main and rod bearings or at leat tell you what size you will need
    1988 "Beater" Avanti---R2 R5388 @ Macungie 2006
      Yes, the crank will need to be re_ground as there are some pretty heavy score marks on it. Am wondering if it would be cheaper to get a new crank vs having this one turned.
        Yes, if you can find a good NOS 259" crank it is about a wash with regrinding the one you have.
        No, not all are good. A few of the remaining 259" NOS crankshafts can be used as is. Most have to be at least polished and more than one has had to be reground.
        Maybe, you should check with the NOS vendors and ask what they'll promise to deliver.
        thnx, jack vines
          Studebaker International has nos 259 cranks. Jim
            I have NOS cranks for 289 & 259'- also have reground cranks & oversize bearings in stock. Wisconsin Studebaker is also a good source of NOS 259 cranks for much less than SI.
            Barry'd in Studes
            Barry'd in Studes
              I have a rod bearing that has the same number on it. Like many manufacturers, Studebaker didnt always use part numbers but casting numbers or possibly engineering numbers are on the part.
              60 Lark convertible
              61 Champ
              62 Daytona convertible
              63 G.T. R-2,4 speed
              63 Avanti (2)
              66 Daytona Sport Sedan
              60 Lark convertible V-8 auto
              61 Champ 1/2 ton 4 speed
              62 Champ 3/4 ton auto
              63 G.T. Hawk R-2,4 speed
              63 Avanti (2) R-1 auto
              64 Zip Van
              66 Cruiser V-8 auto
                The rod with the spun bearing almost certainly needs to be rebuilt, or if the big end is too badly distorted, replaced.
                The other rods' big ends should be checked for size and roundness ( and magnafluxed first, also checked for straightness)
                page 35 - here
                http://mahleclevite.com/publications/EB-40-07.pdf
                  That is a Studebaker part number for one bearing shell half. It never appears in parts books or price lists because no one sells just half a bearing.
                  So.....if I'm 'pre-approved' why do you want me to fill out an application?
