Opinions Please
  • Opinions Please
    I would like feedback on the following:
    The Avanti needs an entire exhaust system. Mufffler shop quoted 440-480 to bend all eight pipe and install.
    Should I purchase said pipes from Stude vendors? The shop will charge me 85/hr labor to install my own supplied pipes.
    What would you do??
    get a price from Don Simmons, might be worthwhile to order from him. His pipes are stainless and if it takes more than two hours to install, even on an Avanti, something is wrong - have had excellent luck with fitment on several cars.
    Of course, if you're getting the entire system, you could probably install it yourself if you have a Sawzall or 4" grinder. You'd need to get new hangers maybe but that's really the only gotcha. Of course new clamps as well, stainless is nice there too.
      If they are bending aluminized and you would prefer stainless, buy the pipes and mufflers from Don Simmons.
      You might also find a do-it-all body shop. Their labor rates are often limited by what insurance companies pay them. Just a thought.
      '33 Rockne 10,
      '51 Commander Starlight,
      '56 Sky Hawk
        The alum pipes in there are about 20 years old.......ss would be overkill! as the alum lasted almost two decades!
        personally I think the bending machine at the muffler shop would not be as good as the pipes from any of the vendors because they are bent per factory drawings...correct????
          A shop that does a lot, and I mean a lot, of exhaust fabrication should be able to make them "as good" as any. Won't look factory, if that's what you want.
          The last dual system I had fabbed on my '63 Cruiser was from manifold back, [u]WHILE I WAITED!!!</u>
          That was at least a dozen years ago, the price was $350 and, I did drive a bit out of the way to get that price. while the car is no longer mine, it continues to "burble" <s>like</s> as it should.
          '33 Rockne 10,
          '56 Sky Hawk
            Simmons. Simmons, Simmons, Simmons.
              I need a complete exhaust system for my full package Hawk. How do I contact Don Simmons?
              Allen
                I found his contact info.
                Allen
                  I just got a new set of stainless pipes and a muffler from Don Simmons (Silvertone) for my Transtar (they look great and will fit perfectly), last year I picked up a set of clamps and hangers from SASCO and it'll be a do it yourself project over the Easter long weekend... 'course it's definitley easier to work under a truck.
                  <h5>Mark
                  '57 Transtar Deluxe
                  "Star Performers with Saving Ways!"
                  Vancouver Island Chapter
                  Mark Hayden
                  '66 Commander
                  Zone Coordinator
                  Pacific Can-Am Zone
                    Don is the only way to go.
                    I put a Stainless dual exhaust in my Hawk and the fit was perfect and took me an afternoon to install. I put a complete dual exhaust system in the Lark and fit perfect. That job took a little longer to fabricate a sheet metal hanger on the rear drivers side. I should have thought to ask Don for that part too but it slipped my mind. Don supplied me with SS hangers, U bolt clamps,pipes and mufflers.
                    No mistake about it, Don's a great vendor with a great product.
                    Allen
                    1964 R2 GT Hawk
                    1963 Daytona Convertible
                    Oakville, Ontario.
                    Hamilton Chapter
                    1964 GT Hawk
                    PSMCDR 2014
                    PSMCDR 2013
                    Victoria, Canada
                      Is it true that one has to make slits in the ends of the pipes where they slide into each other because the clamps will be unable to 'crush' the two ends together?
                      does one have to use ss u clamps?
                        The stainless steel pipes are very hard to crush for a tight fit. I cut my S/S flared pipes with about a 1.5" cut to get a better seal on the pipes. It works out well and is easy to the remove the exhaust when you have to pull the transmission at a later date.
                        Don Simmons sells complete kits with S/S pipe clamps. The nice thing about the S/S, ... it does not rust and is a snap to remove. The cost difference is negligible for the clamps.
                        Allen
                        1964 R2 GT Hawk
                        Oakville, Ontario.
                        Hamilton Chapter
                        1964 GT Hawk
                        PSMCDR 2014
                        PSMCDR 2013
                        Victoria, Canada
                          Don's pipes are on my Avanti and my '53 Starlight; they are also on my Daughter's Jet Thrust powered '57 Transtar. We need to get Don on the computer... but for now his contact info is Silvertone Exhaust Systems in Ontario. Call at 519+485-1966. He is always in South Bend for the Spring Swap and a simple phone call will have your pipes in his trailer!
                          duane miller
                            I have to start this with the expression.........in a pigs ear........Some have proffered that one could remove and install a ss exhaust system in an Avanti in under two hours.........IN A PIGS EAR!
                            Ulilizing my buddies lift it took over four hours to complete......and we had a torch to burn off the pipes!
                            This is not a plug-in-play job, that's for sure:-(
                            On a pleasant note the exhaust sounds great....with burping pulsations!
                              Maybe just the install. I cut my old ones off with a grinding wheel and it took a long time and a lot of oil.
