Throttle shaft arm loose
    Brazing it, is the only fix I know that works without replacing no longer available parts like the throttle shaft.
  • HammondA100
    started a topic Throttle shaft arm loose
    On my WCFB carb the actuator lever or throttle linkage lever is loose or wobbles thanks to the incorrect adjustment of the accelerator rod. Is there a fix for this? The "peened" part is warn enough so there's play before the unit actually moves the throttle shaft.
    I was hoping there was a replacement throttle shaft available with a drilled & tapped end for a locking type machine screw.. I guess it could be welded or soldiered but wanted to see if there was a typical fix for this aggravating problem.
    Wow, someone in this town has something other than a Chevy!!
