brake lines and switch
  • brake lines and switch
    I am tying to figure if this configuration is for a dual master cly or just something someone made up, take a look at this pic and please tell me what this is? this is found on my drivers side inner fender well
    Studebakers forever!
    Someone eliminated the power brake booster. Those two short flexible lines would connect to the booster but someone just tied them together with a brass T-fitting and screwed the brake lite switch into it.[B)]
    Miscreant adrift in
    the BerStuda Triangle
      yeah, what Mr. Biggs said.
      that said, do you have Saginaw power steering? would you mind snapping a few more pics of that setup? specifically how the hoses are routed?
      thanks,
        OK, I see that this poor car has been though it.Would this car function without the booster? What kind of booster would I need to replace it and what additional parts would I need to make this thing complete and work as it did in the beginning.
          You need this booster and mount. Looks like you may have the mount.
          JDP Maryland
            WOW I wonder why they left that out. Where can I get one? are they expensive? Will the little rubber lines attach to the pump directly? I need that pump.[8D]
              It's not a pump, it's a booster, but yes your lines will attach. I get $200 to rebuild one, but you'll need to find a core. ($50-$100)
              64 Commander 2 dr.
              64 Daytona HT
              63 Avanti R1
              63 Daytona convert
              63 Lark 2 door
              63 Lark 2 door #2
              62 Daytona HT/ 4 speed
              62 Lark 2 door
              62 GT Hawk 4 speed
              60 Lark HT
              60 Hawk
              59 3E truck
              52 Starliner
              51 Commander
              JDP Maryland
                The mount shown is actually just the fenderwell mount for the two lines. The booster mount is heavier gauge metal and bigger.
                You'll also need the vacuum line to the manifold and the little one way valve between that line and the hydravac.
                The booster on the two disc brake cars I've owned did not have the second bleeder in front of the little air filter. Were there two types of hydravacs?
                Bellingham, WA
                  here are some pic's of the power steering hoses, I can't get close right now however maybe later I could get you a better shot.
                    oops... never mind, you have the later type box, thanks for trying tho
                      Yes. The kind for disc brakes doesn't have the second bleeder. I think there are other minor internal differences. They seem to work interchangeably but I suspect the disc brake model has a little more capacity (cylinder travel?).
                      [/quote]
                      Tim K.
                      '64 R2 GT Hawk
                      Tim K.
                      \'64 R2 GT Hawk
                        Don't know about the extra bleeder, as my car is supposed to have an NOS unit and it's in pristine condition. It has two bleeders.
                        I believe the Hydrovac for disk brake cars had more pressure. There was supposedly a service kit installed by dealers, for complaints regarding poor brake performance, with disk brakes. The standard Hydro gives around 700psi, the 'kitted' unit was around 900.
                        64 GT Hawk (K7)
                        1970 Avanti (R3)
                          Studelover; Please keep in mind, if you do not replace the Hydravac, you will have the short brake pedal shaft for power brakes instead of the long one that you need. If you notice your pedal should be low to the floor if it still has the "Power Brakes" pedal shaft. Also those booster flex hoses are way past due for replacement, please do yourself a favor and order new ones from a Studebaker Parts Vendor at: http://www.studebakervendors.com
                          Rich.
                          Studebakers Northwest
                          Ferndale, WA
                            thanks your correct about the pedal, I want to put the system back to the correct application. I will be at the keystone swap meet and I will be looking for a booster and a good steering wheel.[8D]
                              I've had a bunch of Studebaker Hydrovacs rebuilt, never saw one with a single bleeder.
                              64 Commander 2 dr.
                              64 Daytona HT
                              63 Avanti R1
                              63 Daytona convert
                              63 Lark 2 door
                              63 Lark 2 door #2
                              62 Lark 2 door
                              62 GT Hawk 4 speed
                              60 Lark HT
                              60 Hawk
                              59 3E truck
                              52 Starliner
                              51 Commander
                              JDP Maryland
