See more
See less
engine temps
  • hank63
    Many years ago, I had a -64 Hawk in Northern Europe. It had one heater only and it was nowhere near good enough on cold days. It simply didn't have enough calory output (kiloJoule these days, I expect).
    /H
  • JDP
    Your climate is the reason Studebaker offered a second heater core under the drivers seat as a option.
    64 Commander 2 dr.
    64 Daytona HT
    63 Avanti R1
    63 Daytona convert
    63 Lark 2 door
    63 Lark 2 door #2
    62 Daytona HT/ 4 speed
    62 Lark 2 door
    62 GT Hawk 4 speed
    60 Lark HT
    60 Hawk
    59 3E truck
    52 Starliner
    51 Commander
  • Carl Purdy
    I had the same problem with the 51. It was the heater core under the seat. Took it to a radiator shop they boiled it out. Put it back on worked good. About a month later I went out to the garage and seen anti freeze on the floor. The heater core looked like a lawm springler
  • Dick Steinkamp
    quote:Originally posted by Mr Mike
    Temps are running about 160 at hiway speeds which isn't enough to activate the new 180 themostat so I don't get any hot water circulating through the heater.
    The heater connections are on the engine side o the thermostat, not the radiator side. The thermostats job is to keep water from circulating through the radiator when the engine is cold. It can't stop it from circulating through the heater. The thermostat should have no effect on the heater. With the engine running 160F, you should have 160F water running through the heater core no matter what position the thermostat is in.
    Maybe kinked heater hose, bad heater core, bad heater control valve?
  • 64V-K7
    more cardboard would help....
  • chocolate turkey
    I have never had a problem with interior heat in my Studebakers and I've run in -45 f. (or c.) many times over the years. I used a 180 t-stat and had good heat. I would venture to say that you may have a partially plugged heater core. That seems to be the culprit in many cases.
    Brian K. Curtis
  • Mr Mike
    started a topic engine temps
    engine temps
    Hi All,
    The temps here in SD have been pretty cold, -10 to 10 F, and my 60 Hawk doesn't get warm enough to provide much heat from the heater. Temps are running about 160 at hiway speeds which isn't enough to activate the new 180 themostat so I don't get any hot water circulating through the heater. I covered up about 50% of the radiator with cardboard which didn't do much at all. At idle, it will heat up and cycle the thermostat and provides more than adequate heat. Is this a pretty normal thing? Will switching to a viscous fan drive help and can the I use the '64 model?
    Any other suggestions are more than welcomed.
    Thanks
