63 Avanti R1, alternator
  • 63 Avanti R1, alternator
    Some time in the past the original alt was replaced with a modern one, Mitsubishi, and the voltage regulator was bypassed. I want to install something more correct and to use the original voltage regulator, instead of the present set up. What do you recommend?
    you could either locate a good used original one (they're out there) or the old MoPar externally regulated alternators are a bolt in and use the same regulator.
      Here's a used one;
      http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
      JDP/Maryland
      JDP Maryland
        For an R1? I used a GM, there is a thread on here. I have the one I
        took off, but the regulator was toast.
        Tom
        '63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
          I believe you can use a Chrysler transistorized regulator with the original Prestolite alternator, if the difference in appearance doesn't bother you.
            Oh, I thought you meant you could use a Chrysler altenator on an Avanti
            R1 engine, I have seen them on standard V8s but not an Avanti R1. The
            mounting is different. The GM one I used did away with the regulator.
            Tom
              Tom
              I believe it goes both ways, you can mix and match with impunity.
              I don't know if the different brackets of an Avanti make it harder to mount the Chrysler alt. or not.
                You can purchase an original looking Prestolite regulator external case with electronic internals vs. the mechanical sytle regular internals from Dave Thibeault. You can probably get this from other vendors as well.
                My Avanti has original Prestolite alt. with electronic regulator works great and with my restoration, I plan on keeping them both.
                John
                63R-2386 under restoration & modification
                John
                63R-2386
                Resto-Mod by Michael Myer
                  My 64 Hawk R1 has a Chrysler alt.if that helps any?
                  Joseph R. Zeiger
                  Joseph R. Zeiger
                    Here's a link to alternator info from Bob Johnstone's website (a great resource)
                    http://www.studebaker-info.org/rjtec...ml#Alternators
                    John
                    John
                    63R-2386
                      Yup, my GM alt install on my R1 Avanti is there :
                      http://www.studebaker-info.org/tech/...vdelcoalt.html
                      Tom
                        The Hawk and Lark R1's mount in the traditional Studebaker way, the
                        Avanti mounts upsidedown.
                        Tom
                          There is a thread here somewhere, where a guy used a Toyota alternator. It fit the brackets perfectly, and it looked less conspicuous than the GM or Chrysler swaps.
                          I just had mine rebuilt and it needed a new stator, along with brushes and bearings. $200!!!
                          But it works great!!!
                          63 Avanti R2, 4-Speed, 3.73 TT
                          Martinez, CA
                            That was listed for an R2, not sure if its the same as an R1 (John
                            Winn, with Addendum by Ernie R)-
                            http://www.studebaker-info.org/tech/...lt/toyalt.html
                            Toyota autolite? on an R2 :
                            Vs the GM on the R1 :
                            Tom
