Flanged axle disassembly question
  • Flanged axle disassembly question
    I just got a pair of flanged axles for my '64 Daytona, including the bearings and seals. I don't have a '65 manual, so how do I get the bearings off to clean and pack them?[?] Is the inner axle seal the same??
    Since I'm doing a major rebuild of the front end, I might as well pull the rear drums, check the brakes, and replace the tapered axles....$$$
    Thanks for any help!!
    To change the bearings on an original Studebaker axle you need to go to a machine shop that has a press. The old ones are pressed off and the new ones are pressed on.
    John
    63R-2386 under restoration & modification
    John
    63R-2386
    Resto-Mod by Michael Myer
      Why replace the tapered axles when you can get a pair of flanged axles that are easier to service afterwards? Otherwise, if you keep the tapered axles the bearings can be packed without pressing them off the same method as you would pack the front bearings by hand. Remember to put all the shims on the right rear back between the axle housing & the brake backing plate.
      60 Lark convertible
      61 Champ
      62 Daytona convertible
      63 G.T. R-2,4 speed
      63 Avanti (2)
      66 Daytona Sport Sedan
      60 Lark convertible V-8 auto
      61 Champ 1/2 ton 4 speed
      62 Champ 3/4 ton auto
      63 G.T. Hawk R-2,4 speed
      63 Avanti (2) R-1 auto
      64 Zip Van
      66 Cruiser V-8 auto
        If your attempting to replace tapered axles with later factory flange axles, they are splined different and require a carrier change. Otherwise requires after market axles. The seal is different and kind of pricey from vendors who have them. I never located a contemporary comparable to the original in size. The retaining ring for the bearing also appears to be kind of rare.
          The splines on the flanged axles are the same as the tapered-both are model 27s. I guess I can clean and pack the bearings w/o taking them off. I will have to get the drum hubs pressed off, tho. I'll have to get a '65 manual I guess for the finer points of the flanged ones.
            My mistake. I assumed 44. The 44 & 27 use same flange axle per parts manual.
