Water pump Impeller removal?
  • Water pump Impeller removal?
    i picked up a new water pump seal for my #527070 pump
    and i was wondering if there are any tricks for removing the impeller?
    do i only have to remove the clip and press it out?
    and the seal was easy toget
    i just went to a local pump rebuilder(not an automotive one)
    and it looks like its a standard pump seal
    i have already looked at http://www.studebaker-info.org/tech/...wpc1/wpc1.html
    it does look straight forward i just dont want to break it
    The seal will do you no good without a new BEARING! [:0]
      Tricks for removing the impeller.
      Here's what I did, I had to relieve the back of the jaws to fit inside the housing. Also, I gently washed the flame from a bottle torch over the central part of the impeller.
      My purpose was to adjust the distance from the flange to the corner of the fins, but pulling it would be the same.
      Tom Bredehoft
      ....On the road, again....
      '05 Legacy Ltd Wagon
      All Indiana built cars
        its a long story [:0] but the bearing is new also
        Tom Bredehoft
        that is a good idea, i guess i should buy another china 3 jaw puller, because i broke the last one
