I have a 1950 landcruiser, original condition with 51,000 miles. Yesterday I drove about 3 miles parked for one hour and when I came out the battery was totally dead. No lights etc. Had to have the car towed home. today we were trying to fix the problem. We charged the battery overnight and todaay, no luck. I did notice while driving the car yesterday that the ammeter was jumping back and forth. We tried jumping the starter solenoid to no avail. We coud not find any bad connections and we cleaned the battery terminals and when we pulled the starter switch, it turned over once. when we pumped the gs and tried again, the starter turned once and the battery exploded. Acid all over the engine compartment. No one was hurt, only loss of hearing for about ten minutes. This is of course a 6volt battery, positive ground. We have ordered a new voltage regulator and will wait a few days before installing a new battery and trying again. Anyone have any ideas? One additional thought. when it would not start, I was checking the battery cables and the positive cable was very hot.any help would be appreciated.
exploding battery
Hot battery cable is telling me there was a huge current. There is likely a bad short someplace. Could be in the generator/regulator circuit someplace but the wire gauge there seems unlikely to support a bad enough short to make the battery explode. I'd also check the starter and solenoid. If this car has all original wiring, the cloth over rubber insulation is likely gone bad and could be crumbled away and allowing a short to the car body/frame.
Jeff in ND
'53 Champion Hardtop
Jeff in ND
I had a 6 V battery explode on me once. BANG! Battery acid all over the place.
It happened when I boosted it with a 12V.
I've boosted 6V with 12V many times before and many times after.
I just think that this battery was shorted inside AND gas had built up under the caps. The perfect storm.
PS: Yes, I do stand back a little more when I do it!!
Battery cable getting too hot? Means something is drawing a pretty huge current. A bad starter can do that. If the bushings are worn in the starter, the armature can drag on the pole shoes for the field, and current draw really shoots up, if it is able to crank the engine at all.
On a six-volt car, using 12-volt rated (undersize) battery cables almost gurantees the cable will get hot, even if the starter is good. Since most parts-store battery cables on the racks are made for 12-volt service, it's VERY common to find six-volt cars with incorrect battery cables.
Some batteries are just plain defective. The current-style hard-top batteries have their inter-cell connections in the form of a spot weld between lead tabs on either side of the bulkhead between cells. There's a hole in the bulkhead; the spot welder presses these tabs to meet through the hole, and current is applied to make the weld. The welding process is just like that used to make spot welds on body panels, but the metal is MUCH thicker. Occasionally, you get a bad spot weld, and the battery will become intermittent. It might run the lights OK, and test good with a hydrometer, but the bad weld won't pass enough juice for the starter, and an arc occurs at the break. If this happens just after charging, when the air space in the cells is filled with hydrogen, Ka-boom! happens.
If you dissect the exploded battery, you might see the tell-tale signs of such arcing if you trace the current path through the cells. Be sure to wear protective clothing if you try this! If the battery was fairly new, and still under warranty, best to have the dealer who sold it do that.
Gord Richmond, within Weasel range of the Alberta BadlandsGord Richmond, within Weasel range of the Alberta Badlands
It's happened to me twice in past ten years. Both were 12v batteries in relatively late model vehicles (GMC truck and a Porsche). As mentioned in preceding post, both exploded very violently during starting. Probably coincidental, but both were same brand (DieHorribly?). Sears store people just shrugged and said "it happens". I'm fervently hoping that violent explosions and showers of acid should be less likely with products (such as Optima and Odyssey) NOT filled with liquid acid.
Gil Zimmerman
Riverside, CA
1955 Speedster
1956 Golden Hawk
1958 Packard Hawk
1958 PresidentGil Zimmerman
Riverside, CA
1955 Speedster
1956 Golden Hawk
1958 Packard Hawk
1958 President
1963 Avanti R2
I am surprised that Gord and others did not mention this. Be sure that you immediately neutralize the acid and wash everything down well with water.
Hiding and preserving Studebakers in Richmond, Goochland & Louisa, Va.Join me in removing narcissists, trolls, self annoited "experts" and general idiots via the Ignore button.
Gary, you are quite right about neutralizing the acid, and washing down with water. I didn't mention it, because with the time that has passed, it'd be like locking the barn after the horse has been stolen.
gary was right aboutthe acid. the first thing I did was to get the hose and completely wash the engine compartment and the exterior, including my arm which was sprayed. thanks for all the comments. We will try again when the voltage regularot and the new battery arives
I've seen a 6 volt battery explode because it was jumped with 12 volts. The battery was frozen at the time and the guy that jumped it knew better. I blew up a 12 volt battery beacuse I was careless and didn't turn off the high current charger when I disconnected it. There must have been a large amount of hydrogen gas venting from the battery and the spark from disconnecting the charger was enough to blow the top off of the battery. Fortunately in my case, the battery was on the bench and not in the car, but I still ruined a Die Hard battery. Bud
Funny story that could have been serious: My friend on a cold winter night in NH decided to check his battery water level with a lit match! He came back in OK, less eyebrows........
'59 Lark hardtop w/355 blown sbc, 700R4, 8.8" rear w/ 3.73 gears
Dogs are a man's best friend. Just ask my Dachshunds!
