See more
See less
Ah, the joys of engine swaps
  • JGK 940
    That's why I love this forum - you guys give me hope there's still folks out there willing to figure out how to git'erdun RIGHT and put some muscle and pride into making it happen.
    Good on you, Dan. I want one of the first rides when she's done - right after the photo session you're about to promise me
    Keoni Dibelka / HiloFoto
  • Michidan
    The brake line is actually no problem, farther than it looks. The gas line runs along the frame here though, trying to keep that far away as possible...
    Was just looking at that picture and reminded myself to grab a 90 zerk fitting. I'd hate to have to pull he motor to grease the suspension.
    www.studebakerhardtop.com
  • Dick Steinkamp
    quote:Originally posted by Michidan
    In other words, this is how to turn $170 headers into $500 headers.
    Beautiful work! []
    Dick Steinkamp
    Bellingham, WA
  • sweetolbob
    quote:Originally posted by Michigan
    Gonna do er up right
    Dan
    Way to nice a vehicle to cobble-up a solution. CASO be darned in a case like this.
    Down the road, you'll be glad you did it this way every time you open the hood.
    Me likee lots.
  • Jeff_H
    That weld job looks great.
    Is there any concern of the close distance to the brake line and the heat from the header? Looks very close in the picture.
    Jeff in ND
    '53 Champion Hardtop
  • Michidan
    Update. Warning, the following solution is not CASO approved.
    But as the A arm interference was too much to notch around, something proper had to be done. Here is the passenger side after a new tube has been made. This is beyond my skills. Local racer did this work and it is excellent. His Tig welding is suberb.
    He's also doing the drivers side, and building custom collectors on the bottom, to get me past the tie rods. Gonna do er up right.
  • laughinlark
    Hey Dan,
    If it was mine. I would cut and reroute the one tube. A couple of cuts, a couple pieces of pipe, and a couple PBR's and it will be good to go. A good exhaust shop could do this for you with the header off & some sharpie marks from you where to cut. They would probably like doing this verses putting a farting muffler on an Import. [}] I would be concerned with the cooking the upper bushing if the tube isn't moved. Some header wrap would go help too.
    Gordon
  • Michidan
    A good estimate of area at the narrowest point is 64% of full tube area. The transistion into and out of this neck will be pretty smooth. Still have not decided, last night I moved over to the other side. Same problem, but with #3 cylinder. We'll see how much that one eneds cutting...
  • rickhmn
    I think you are fine on the exhaust with your power goals. Standard cast iron manifolds will support that kind of power and even with your restriction you should outflow the stock cast manifold.
  • Michidan
    Thanks all.
    I'm glad for the opinions. I can't have you all standing the garage with me, having a PBR and staring at it. So this post is my virtual bull session about what to do.
    Don't think I don't enjoy the challenge! I'm thrilled it's only one tube causing trouble! After all I'm the fool who waited this long before tackling the headers. Should have been figured in years ago.
    Alex, I ran fenderwells on first hot rod, 66 Nova. They are cool but also not without certain challenges.
    Way too late to talk about motor position, but I'll assure anyone doing a swap like this in the stubby 52 chassis...your motor will also be in this spot. It's the one spot between firewall and clearing the steering with the oil pan. You would not want the motor any farther forward anyway. To go rearward requires full width new firewall. (even now it's notched.)
    Anyway, the #2 tube sticks out farther becuause of where it goes into the collector. On the southeast corner per the picture. These tubes are not going to bend. I like the bulge idea, this could be done opposite the cut out.
    It's either that or bring the whole tube up and over. Requires cutting the whole collector off, and re-welding all the tubes back on after the new one is made. And that's going to kind of block a spark plug too.
    Thomas was glad to hear your opinion. I have a local racer here also say that BBC exhaust is plenty big for my ~450 HP plans.
  • Thomas63R2
    Dan, it is impossible for me to tell from the supplied pictures - but it looks like you could have the #2 cylinder primary go straight down for ~ 6" before going back to meet the collector and you would miss the upper a-arm traffic jam.
    Alternatively you could have that primary come up, go over, then down - but that would make it crowded in a different spot.
    By the way, on BBC up to ~ 700 hp I have never found much if any power impediment from having just ONE pinched primary tube, especially when the pinched spot is only 2" or 3" in length. Looks ugly, but no real power impact. If the tube was flatened for 6"+ then it is a problem, or if more than one primary is flattened that is a problem. As it is BBC ports have their own variations in flow anyhow.
    Thomas
  • Jessie J.
    Kind of extreme over having to reshape/reroute a few inches of exhaust tube. Looks like if it was tucked in as tight to the flange as the next tube there would be no interference.
  • sweetolbob
    quote:From BAMS50
    That's why I don't think I will ever tackle a job like that, it would make blood just shoot out of my eyes
    Aw Shucks, Dan. If was easy, everybody would be doing it, like golf.[)]
  • bams50
    Let us know what you decide.
    Parish, central NY 13131
  • sweetolbob
    Dan
    You'll need the Studebaker Racing guys on flow etc, but if it was mine, I'd think there is too much restriction. I'd bulge the pipe out in the most convenient direction to make up for most of the volume lost.
    To make my headers fit in the 54K, I cut the top of a couple of pipes almost through, bent them down close to the block and added metal back to the pie shaped area. Had to make a few adjustments to the pipe location and position.
    Remember if you get real close, it can be wrapped with header wrap.
    If you can't make it purddy, make it go fast.
