GT Hawk problem areas
  • #16
    Right Jerry - the inside skin of the trunk lid is the same on the GTs as the earlier C-Ks, a cost-saving move I'm sure. Russ Farris
    1963 GT Hawk R-2 4-speed
    1964 Avanti R-1 Auto
    • #17
      I'm with PackardV8 in balancing this out with some positives. One of the major ones that I would add is the EXCELLENT handling and front-rear weight distribution. A GT Super Hawk with radius rods and rear stabilizer can take on anything of its era in the handling dept., and a lot of what has come after as well. And for driving in snow, the balanced weight distribution makes the GT more sure footed than any other rear wheel drive car I've ever driven.
      Gene Nagle
      1963 Hawk R1
      Gene Nagle
      1963 Hawk R1
      1985 Avanti
      • #18
        I am not sure if this design was changed later on, but the hardtops(the versions with no B pillar), had something that resembled hog troughs underneath. They went from behind the lower rocker panel to the outside frame rail and looked like spot welded strips of sheet metal underneath. They are under the floor, kinda like a sub floor. These will rot through over the years, and unfortunately, they give strength to the body of the car since the pillar is not present in the hardtops, and keep the car and its body from flexing. You may go to look over a hardtop and perfect floors, but have these hog troughs rusted away.
        These are also available from our vendors(Classic Enterprise to name one).
        [IMG=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/55%20Studebaker%20Commander%20Streetrod%20Project/P1010531-1.jpg[/IMG=left]
        [IMG=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/55%20Studebaker%20Commander%20Streetrod%20Project/P1010550-1.jpg[/IMG=left]
        [IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/Ex%20Studebaker%20Plant%20Locomotive/P1000578-1.jpg[/IMG=right]
        [IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201964%20Studebaker%20Commander%20R2/P1010168.jpg[/IMG=right]
        • #19
          yes, there's definitely POSITIVES to owning a Studebaker
          - parts availability (except for rust free front fenders)
          - vendor support
          - knowledgeable community
          - bulletproof mechanicals - despite the comments above about the front suspension bushings, the front suspension is pretty "fail safe," e.g. you can have bushings running metal to metal, sloppy, worn out kingpin bushings, and trunnions seized up and flopping around in ways the factory never intended and the car will still drive "OK." Not that I would recommend driving like that, but there is no common failure which will result in the front end of your car crashing into the pavement like there is with a ball joint front end.
