BALL JOINT QUESTION
  • BALL JOINT QUESTION
    The top of the bolt on a ball joit is slotted for a screw driver...why is that ? What function does it have ? ,,,thanks, John
    So you can hold it with the screwdriver while tightening the nut???
    3E38
    4E2
    4E28
    5E13
    7E7
    8E7
    8E12
    8E28
    59 Lark
    etc
      So you can turn the bolt to the correct position for cotter key installation before tightening the nut.
      Just a WAG.
      That's what I use it for.
      JF
      Jerry Forrester
      Forrester's Chrome
      Douglasville, Georgia
      Jerry Forrester
      Forrester's Chrome
        I don't understand the question. What is a ball joint?
        Bez Auto Alchemy
          Studebaker did not use ball joints.
          Tie rod ends we call them.
          Robert Kapteyn (old geezer)
            A question that would come from only a true Studebaker knut.
            Jerry Forrester
            Forrester's Chrome
            Jerry Forrester
            Forrester's Chrome
              On a Studebaker, he would have to mean a Tie Rod End, however everyone was being nice enough not to tell him!
              Not me, I'm all about tell it like it IS! [)]
                That's what I was thinking too <G>
                Jeff DeWitt
                http://carolinastudes.net
                Jeff DeWitt
                  Strictly speaking, a tie rod end is a ball joint, just not what a mechanic thinks of when you say "ball joint." Unless it's a Heim joint or rod end, in which case then it isn't
                    Studebaker used king pins before ball joints came into play. They all did. Studebaker used them till the end. jimmijim
                    Stude Junkie+++++++Do it right the f$$$$ Time. Never mind. Just do it right. When youre done your done. You'll know it.
                        Maybe he's working on a brand X that has a ball joint?
                        Maybe not. But it never hurts to be opened minded...
                        John, to answer your question, I have no idea what the slot is for.
                          Both Charlie and Jerry answered right, as far
                          as what it is used for. I have always used the slot
                          (on the ones that have them) to position and to
                          hold while getting tight on the taper.
                          Tex E. Grier
