63GT New motor mounts-GROUNDS ?
  • 63GT New motor mounts-GROUNDS ?
    Replaced the four engine mounts-the old ones were putty and had let the
    motor slide forward over an inch. I need advice on grounding the motor,
    now that it is nicely insulated on new rubber, to the chassis. I'm thinking the easiest
    thing would be to run a grounding strap from the tranny mountbolt to some place
    nearby on the chassis. Also, probably a good idea to run one to the firewall
    and pick up the dash side with a lug and wire to provide a good ground for the fiberglas
    dash instruments. Any suggestions?
    1950 Champion Starlight
    1963 Hawk GT
    Santa Barbara
    CA
    The 1950 Champion Starlight
    Santa Barbara
    CA
    The strap mounts on the passenger side mount bracket bolt, the other end is held by a self tapping bolt into a hole in the frame.
    (see strap in engine picture)
    64 Commander 2 dr.
    64 Daytona HT
    63 Avanti R1
    63 Daytona convert
    63 Lark 2 door
    63 Lark 2 door #2
    62 Daytona HT/ 4 speed
    62 Lark 2 door
    62 GT Hawk 4 speed
    60 Lark HT
    60 Hawk
    59 3E truck
    52 Starliner
    51 Commander
    JDP Maryland
      Here's how my '63 is grounded. This is the right front motor mount...
      Bellingham, WA
        I used a small grounding strap from the engine side of the motor mount to the chassis side, running it along the inside (engine side) of the mount. It is nearly invisible and works great. For the chassis to body ground, I used a strap between the two, mounted with self-tapping metal screws. Also works well. As for the instruments, most electric instruments are "grounded" to their sending units, and work in some magical way that us non-electrical engineer types don't really understand but do appreciate. Dash lights, etc., do need grounding.
        jj
          Dick's pic, AFAIK, shows the exact method used by the factory.
            Thanks all!! Dick's photo was especially helpful because when I looked to install
            a ground cable as shown in the picture--there was already an original one there.
            Old eyes I guess cause I never noticed it before. The new mounts were installed from
            below using a lift .
            1963 Hawk GT
            Santa Barbara
            CA
            Santa Barbara
            CA
