Floor shift manual backup light switch ???
  • Floor shift manual backup light switch ???
    We have 3 speed floor shift top loader (no linkage) transmission in our 57 silver hawk We are restoring;
    1) can someone tell us how to identify it.
    2) How do you hook up backup lights to a top loading tranny.
    Happy New Year,
    Dick Curtis
    The 1950 Champion Starlight
    Santa Barbara
    CA
    Well that depends Dick, on what top loader you are talking about. If it's a late model Ford or Dodge, they usually have a switch location built in somewhere.
    If it is a Stude. Borg Warner T-90 or <s>T-85</s> T-86 with a '37 Stude. car or a Truck or Jeep top (shifter) cover, there would be almost no way to activate the switch short of some kind of crude homemade floor mounted switch sticking up 4 or more inches above the floor that MIGHT hit the lever at the right place?
    Update: Correction, I meant T-86, which of course would be almost identical to a T-90
      You may have to run a switch at the top of your shifter to activate manualy when in reverse.
      John
      62' Deluxe R2 4SPD.
      63' R1 Wagonaire
      58' 3E6D Stock
      John
      62' Deluxe R2 4SPD.
      63' R1 Wagonaire
      58' 3E6D Stock 4X4
        Toggle switch on the dash? That's what Dad's '56 two door has..
          There are aftermarket switches that can be screwed into the shift cover of top loader type transmissions. They go into the "tunnels" on top of the cover plate. You may have to tap the hole after removing the small expansion plug filling the hole. The internal shift rod contacts the switch. You just have to figure out which end of the cavity the switch needs to go into.
          http://www.lokar.com/interior_pages/...-switch-fs.jpg
          Jeep used similar switches in transfer cases to indicate a shift into 4wd on Jeep J-series trucks and Wagoneers.
          Your transmission cannot be a T-85/T89C as those have side covers, not top.
          3E38
          4E2
          4E28
          5E13
          7E7
          8E7
          8E12
          8E28
          59 Lark
          etc
            The borgwarner T86 toploader is what my Gibson uses for a transmission. There is no provision for a backuplight switch. I would fiund a good location and mount a toggle switch like I did with my tractor.
            65 2dr sedan
            64 2dr sedan (Pinkie)
            61 V8 Tcab
            61 Tcab 20R powered
            55 Commander Wagon
            54 Champion Wagon
            46 Gibson Model A
            50 JD MC
            65 2dr sedan
            61 V8 Tcab
            63 Tcab 20R powered
            55 Commander Wagon
            54 Champion Wagon
            46 Gibson Model A
            50 JD MC
            45 Agricat
            67 Triumph T100
            66 Bultaco Matadore
              65 2dr sedan
              61 V8 Tcab
              61 Tcab 20R powered
              55 Commander Wagon
              54 Champion Wagon
              46 Gibson Model A
              50 JD MC
              Randall,
              I know that many Gibsons used the smaller T96 B-W transmission. What models used the bigger T86?
              Paul
              Winston-Salem, NC
              Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.com
              Paul
              Winston-Salem, NC
                Put in a rocker switch today for backup lights.
                Thanks all
                ....Dick
                Santa Barbara
                CA
