WILL A WCFB CARB WORK WITH SN92
  • WILL A WCFB CARB WORK WITH SN92
    IHAVE A 55 PREZ COUPE I JUST GOT A SN92 PAXTON WILL IT WORK WITH
    WCFB CARB WITH THIS PAXTON BLOW THROUGH SYSTEM OR WHAT CAB TO USE
    THANKS SPENCE
    We need more info, Spence. Do you plan on putting the carb in a box, R3 style or were you planning on using a bonnet at the top of the carb?
    Tim K.
    '64 R2 GT Hawk
    Tim K.
    \'64 R2 GT Hawk
      goin to use a bonnet
      Tim K.
      '64 R2 GT Hawk
        With the amount of money invested in the entire supercharger setup, it would be false economy to try and use the smaller WCFB. Are using the Avanti style side mount ?
        64 Commander 2 dr.
        63 Avanti R1
        63 Daytona convert
        63 Lark 2 door
        63 Lark 2 door #2
        62 Daytona HT/ 4 speed
        62 Lark 2 door
        62 GT Hawk 4 speed
        60 Lark HT
        60 Hawk
        59 3E truck
        52 Starliner
        51 Commander
        JDP Maryland
          Lots of good info here: http://www.vs57.com/carb.htm
          Hope this helps.
          Tim K.
          '64 R2 GT Hawk
          Tim K.
          \'64 R2 GT Hawk
            have to use side mount to clear hood on the 55prez coupe eny help on this i like to use a serpentein belt on it if tha can happen what other carb can i use thank spence
            64 Commander 2 dr.
            63 Avanti R1
            63 Daytona convert
            63 Lark 2 door
            63 Lark 2 door #2
            62 Lark 2 door
            62 GT Hawk 4 speed
            60 Lark HT
            60 Hawk
            59 3E truck
            52 Starliner
            51 Commander
              You can use a Edlebrock with the marine accelerator pump and some sealing.
              64 Commander 2 dr.
              63 Avanti R1
              63 Daytona convert
              63 Lark 2 door
              63 Lark 2 door #2
              62 Lark 2 door
              62 GT Hawk 4 speed
              60 Lark HT
              60 Hawk
              59 3E truck
              52 Starliner
              51 Commander
              JDP Maryland
                Hey Spence, Come check out http://www.racingstudebakers.com/stl...n/bb/index.php theres lots of good info there also on Hi-perf Studes.
                Jake
                -Home of John Studebaker-
                http://community.webshots.com/user/Stude4x4
                http://varozza4x4.com
                  Greetings, hurricane,
                  There have been successful Paxton/WCFB installations in the distant past.
                  One thing to remember is 4-bbl carburetors are flow-rated at around 1" of vacuum. Add five pounds of boost and a 400cfm WCFB will flow all the air a stock 289" can ingest. The '57-58 Golden Hawks made do with a 2-bbl Stromberg of a much smaller CFM rating.
                  If the combination is a 300" with ported heads, big valves, longer duration camshaft, then a 600CFM Carter or Edelbrock would recommended.
                  thnx, jv.
