radio antenna no up or down
  • radio antenna no up or down
    What heighth should the antenna be at the max and then at the minimum. Is it a tape that coils and goes up and down to drive the antenna and can you uncover it. I have the main housing cover off. Mine will not move in either direction by turning the wheel on the kick panel on a '47 Studebaker and a '52............Brad
    It's a cable that winds around a reel with a clutch. The cover unsnaps and you can see the works.
    64 Commander 2 dr.
    63 Avanti R1
    63 Daytona convert
    63 Lark 2 door
    63 Lark 2 door #2
    62 Daytona HT/ 4 speed
    62 Lark 2 door
    62 GT Hawk 4 speed
    60 Lark HT
    60 Hawk
    59 3E truck
    52 Starliner
    51 Commander
    JDP Maryland
      There's a spring steel pressure plate that fits against a fiber disc. If it has lost it's grip and worn a groove in to the disc you may need to secure it in some manner. It's been years since I had one of these apart. I'm not up to removing mine to resurrect memory so open it up and tell us what you find.
      I actually got mine working using parts from two different antennae so, if yours is all intact, it should be repairable.
        It appears to be rusted in place also. I have lubed it and will let it set for a while..........Brad
          One of my "smarter" moves some years ago was to lube the wind-up antenna on my '53 with a graphite liquid. Can you say "zero radio reception"?
          Museum R-4 engine
            Mine retracts to 6 1/2" and extends to 51".
            Brad Johnson
            33 Rockne 10
            51 commander Starlight
            53 Commander Starlight
