What rearend do i have?
  • #16
    When you pull the cover just check the numbers stamped on the ring gear. There should be a 43-13 stamped on there if it is a 3.31 ratio.
    Jake
    -Home of John Studebaker-
    http://s158.photobucket.com/albums/t...varozza4x4.com
    • #17
      Well IF it is a 3.31 it definetely HAS been changed, as trucks only go as high (low numerically) as 3.73 so your "ear" or Tach. are off, it already is a good cruising, high speed ratio! [^] Maybe you need a new clutch, quieter muffler or more insulation. In fact a "6" could not pull a Truck with a load without burning the clutch up with that high a ratio!! [:0]
      quote:Originally posted by 61rat
      Well it is a Dana 44 w/3.31 gears. Well at least the tag says 3.31 gears. I don't know if they were changed. But I'll keep you updated when i open up the case in a few weeks. Right now I'm trying to find a new motor for the truck. Thanks for all your help guys.
      Studebakers Northwest
      Ferndale, WA
      • #18
        MB writes:
        "My '59 PU has a Dana 44 in it. It had a 4:27 rear originally. Driving it, you'd be in second gear by the time you got to the end of the driveway. It was screaming at 55 mph with the OD engaged."
        Matthew, I've been running 4.27 gears in Pete for some years now. I don't sense him "screaming" at 55. In fact, Pete sounds happiest over 70. And he's happy to do more[]!
        I will say that the stock T-85 3spd is done with 1st gear in a hurry, but that's as it should be. The low gear's for getting started with a load.
        I have a truck rear with 3.73 gears in it that I want to put under Pete eventually. My primary aim is to see if I can eek out another MPG or so. Of course, 1st gear will be more meaningful with that ratio, but that's OK with me.[^]
        Miscreant adrift in
        the BerStuda Triangle
        • #19
          Biggs, what mpg are you getting with pete right now? My dad used to get 18 mpg highway out of the '58 when it was a stock 2 wheel drive with the 3spd OD. I can't remember what gears it had. I think they were 4.27.
          Jake
          • #20
            I haven't checked mileage at all since the new engine and Edelbrock were put in. It used to get 18 on the hiway if I drove it right.
            Pete used to have 4.10s under him and when I switched to 4.27, I really couldn't tell any difference in performance!
            Miscreant adrift in
            • #21
              depending on your tire hieght i would think 4.27 in overdrive would be around 2750 rpm @ 70. my lark without overdrive travels at that allday
              no prob.
              Erin Hays
              1961 Hawk
              1962 Lark
              1963 Wagonaire
