T-Cab rear axle seals
  • T-Cab rear axle seals
    In putting the rear end of my Champ back together I'd like to replace the axle seals, especially the outer one. The inner one, 1685410, is available from SI, but they don't list the outer one, 191023, and neither does the Timken Seal Interchange Guide.
    Anyone have any suggestions?
    Thanks!
    Jeff DeWitt
    http://carolinastudes.net
    Jeff DeWitt
    Not a problem Jeff just take the old seal down to your local bearing place and they can measure it and match up a seal that is still in production. I had to do the same with my T cab.
    65 2dr sedan
    64 2dr sedan (Pinkie)
    61 V8 Tcab
    61 Tcab 20R powered
    55 Commander Wagon
    54 Champion Wagon
    46 Gibson Model A
    50 JD MC
    65 2dr sedan
    61 V8 Tcab
    63 Tcab 20R powered
    55 Commander Wagon
    54 Champion Wagon
    46 Gibson Model A
    50 JD MC
    45 Agricat
    67 Triumph T100
    66 Bultaco Matadore
      Thanks Randall, I'll give that a try.
      I expect they won't be able to help though, I took another look at that outer seal and the housing has a National part number stamped into it, and that's a pretty big chunk of stamped steel. I couldn't find any cross references to that number either.
      Jeff DeWitt
      Jeff DeWitt
        Jeff,
        You can "dig" out the old felt seal and some of our vendors sell the replacement felts. They're easy to replace, I'm sorry I don't know the vendors that carry them, but they're not expensive. Hope this helps.
        Dan Miller
        Atlanta, GA
          Hi Jeff, I think this may be the place I ordered these seals from 18 years ago. I think they were in Michigan at that time but they show a North Carolina address now. I couldnt find a website for them but they advertise in Hemmings as having parts for all makes. This is their ad copied from the Hemmings website: BEARINGS, seals for: axles, clutch, differential, pinion, transmission, wheels, all years. Olcar Bearing Co, 135 James Creek, Southern Pines, NC 28387, 910-693-3324 or brgdr@earthlink.net.
          Or maybe it was this company, Northwestern Auto Supply of Grand Rapids, MI. Yeah, I think thats it.
          Call Anytime: 1-800-704-1078 http://www.northwesternautosupply.com/
          Brent's rootbeer racer.
          In the middle of MinneSTUDEa.
            When I had my T cab, I dug out the old felt seals and replaced them with Stude V8 front crankshaft seals as I had a few on the shelf. They were still on the truck when I sold it in 2005. Bud
              Jeff - My 63 T-Cab's Dana 44 took SKF-19887 outer seals. I replaced the inner seals with a pair of SKF-13862.
