Info for those with Edelbrock AFB's
  • N8N
    good stuff. this is important for those with automatics, because that is the hole that makes the throttle pressure linkage work correctly. I think I fudged mine with some thin stainless washers.
    55 Commander Starlight
  • Laemmle
    started a topic Info for those with Edelbrock AFB's
    Those members who have replaced their AFB's and installed new shiny E carbs........a bit of info.
    If you want to utilize the larger throttle attachment hole on the linkage (1/2 in) you will have to bush the hole........Jegs has the perfect product......P/N 15220 "Steel Carb Linkage Bushing"
    Those wishing an AN alternative to steel are in luck as well:
    P/N 15219.......Aluminium carb Linkage Bushing Kit.
    Thanks to Ernie Rizzo for the suggestion of utilizing the larger hole for the throttle rod.
