1947 Newbie Help
  • #16
    You might contact Dennis Mills. He is a member of SDC in Tucson and has a 49 Champion. superstude at msn.com.. He drive the car from St. Louis to AZ some time back and I am sure it went faster than 60MPH
    Milt
    1961 Hawk
    1964 Convertable
    1967 Avanti
    1961 Lark 2 door
    1950 Commander Starlight
    Milt
    1961 Hawk 4-speed
    1967 Avanti
    1961 Lark 2 door
    1988 Avanti Convertible
    Member of SDC since 1973
    • #17
      Ya didn't do it right? Start over again and make sure you follow the shop manual carefully. jimmijim
      Stude Junkie+++++++Do it right the f$$$$ Time. Never mind. Just do it right. When youre done your done. You'll know it.
      • #18
        If gas started shooting out the clearance hole for the metering rod, then the carburetor float valve is not closing when the bowl gets filled. Valve could be installed wrong, float could be hanging up, or the float could have been punctured and is now sinking. But it's definitely a problem with the float system.
        • #19
          If ithas been changed over to 12 v. the solenoid is fried by now, it being a 6 v.you will need a 12 v. solenoid and the o.d. will be good to go .
          James R Jones
          James R Jones
          • #20
            well it was the float so no gas shooting out of the carb anymore and the car ideled nicely on a gravity feed. My Fuel pump doesn't pump so the new should be here today. I was through the land of OZ (My trunk) yesterday and I found a cable that had OD on it. I still haven't been able to get uinder the car and look at the trans. I hope to post some pics as soon as I get the car on jack stands. Thanks for the help so far and keep checking back, because one of 2 things is going to happen. A.) I get the car on the highway or B.) I will post pics of the fire.
            Thanks,
            Ryan
            • #21
              Call Chuck Collins at Studebaker Parts, I am sure that he can steer you in the right direction to get it fixed. He is one of our vendors and has helped me quite a bit. And he lives there(Phoenix).
