6 volt start
  • 6 volt start
    For quite some time now I have read posts about the need to put proper sized battery cables in a 6 volt car. Everyone said that the 6 volt worked fine so long as the contacts were clean and thick 0 gauge or thicker wire was used.
    "Naw," I thought. "Too easy," I thought. But, I finally got some 0 gauge wire and changed the battery cables and the grounding strap. Got in the car and turned the key. The battery that I thought was dead because it barely, if at all, turned the engine,now worked great. The engine started right up.
    Moral to the story? If you have a 6 volt and haven't changed the battery cables to the proper size, do yourself a favor. It makes all the difference.
    Good for you.
    The other moral to the story is to pay attention, as you did, to what has been learned through a lot of experience by some that post on the Forum.
    Related to this, be sure that you have a six volt battery with enough capacity, not the basic 6V sold by some stores. Group 1 batteries come in different power ratings, the same as any other Group (physical size) battery.
      Rob, you are now a veteran. Congratulations! It pays to listen to guys with experience. One more tip for batteries, always buy a battery with twice the amps as the cubic inch displacement of the engine. Got a 170 ci straight six, get a battery with at least 350 cranking amps.
      '50 Champion, 1 family owner
        Along those lines - when I first purchased my 50 Champion, it had one of those round green disconnects on the battery. I was constantly having trouble starting the car. A friend told me to take that off and throw it away. I did and it made all the difference in the world.
        Doug
        Venice, Florida
        1950 Champion 9G F1
          I've had trouble with cranking speed when using a green battery disconnect on 12 volt systems. Those things are made in China out of inferior parts, that's why they are inexpensive. I would never use one on a 6 volt system as the voltage drop across them is excessive. Bud
            Hey Robtc...
            I tried to send you PM and it was returned stating "Cox.net is Blacklisted"
            That's a big network to blacklist. You know what this is all about?
            Bob Johnstone
            www.studebaker-info.org
            64 GT Hawk
            55 President State Sedan
            70 Avanti (R3)
            64 GT Hawk (K7)
            1970 Avanti (R3)
              I had a '52 Commander that I tried EVERYTHING to get engine (when hot) to turn over, and I've always had good luck w/6volt electrics. It wasn't until I rebuilt the engine and found old fashinon foil type shims under the main bearings! When hot, evidently it caused enough mechanical resistance to bind things up.[B)]
