Hi to all...I am thinking about installing electric wipers on my 1950 Commander...any suggestions of what to use and cost ?
ELECTRIC WIPERS FOR 1950 COMMANDER
Hi Dean..thanks for replying to my query...as my Commander has been converted to 12 volts,I am thinking I would need a 12 volt motor from the the 1st or 2nd year that Studebaker went to 12 volts. I am presuming that was in 1956 ?...This way I think I would have a better chance of the wiper setup being the same...what do you think ?..I am open to all opinions....John
Would a set out of a 52 work?
I have a 52 and it has electric wipers, (I need mine) But it should be just a bolt on application and also should look correct.
Just a thought.
Dean.
[/quote]
I have a 51 land cruiser with electric wipers. I think that the later electrics used a different mount for the motor. Since you have converted to 12 volts, I don't think you should have much trouble except for adapting the bracket. I would think the key would be in getting the motor centered and if you have proper reach arms they should work just fine.
SDC member since 1975John Clary
Studebaker went to a 12 volt system in 1956. By the way, having looked at a '52 and a '53 and a '56 (admittedly the '53 and the '56 were C/K cars), the '52 looks quite different (all have electric wipers). Hope this helps.
Howard
53 Commander Starliner
56 Sky HawkHoward - Los Angeles chapter SDC
'62 GT Hawk (4 speed, A/C, Power steering - running and DRIVING!)
Hi....I guess what I really need is to find out which Electric motor is the most compatible with the 1950 Commander windshield wiper linkage setup so that I could hook the electric motor up with the least amount of problems...Ideally I would want a motor that would just hookup to the original wiper linkage....Does anyone have a 50 and a 56 commander body parts catalogue so that the two systems could be compared ?thanks,John
Howard
56 Sky Hawk
[/quote]
