I have a 61 Lark and the motor smokes. I have access now to a running 232. Can I swap the 232 in where the 259 was and have it work? I am just doin it until funds get better for the 259 rebuild.
232- Later FOM
So long as the 232 has the short flywheel bolts, for the flexplate, there should be no problems. It should be a bolt-in swap.
Tom Bredehoft
....On the road, again....
'05 Legacy Ltd Wagon
All Indiana built cars
Before swapping engines, I would find out why it smokes. Perhaps it only needs something simple like valve stem seals. That repair would be a lot easier than swapping engines. With your proposed engine swap, you will need to address the six volt 12 volt items.
Studebaker enthusiast much longerGary L.
You will have to dial-in the existing housing using different dowel holes so you can reinstall the original engine later.
We are not saying you can't do this, just that it is a whole lot of work for a temporary setup, you would have to change the flywheel of the 232 to a fine a toothed one, for a 12V Starter, and if Automatic the Converter.
StudeRichStudeRich
