quote:Originally posted by bige
You should be able to replace the bearings without going through the whole set up routine. If you don't feel like doing it take it to a shop that does Jeeps they are very well versed in the DANA 44. However sounds like you have most of it apart already.
Remove the pinion yoke or at least loosen the bolt, pull the axles, remove the inspection cover, take out the carrier but make sure the bearing caps are marked to go back in the same place and orientation as they came out. Remove the yoke and with a soft hammer, or hammer and block of wood on the pinion with the nut on to protect the threads, tap out the pinion gear. The front bearing is not pressed on the back one is. Be mindful of all shims and make sure they go back where they came from. There are shims under the race of the inside bearing and they will get dinged removing the race but that's OK. The pre-load shims should stay on the pinion when you remove it just put them back where they were when you assemble. Torque the nut and the washer to 140-180 ft pounds with the new bearings and races and re-assemble the rest. Easier than it sounds.
ErnieR
Best so far 15.065 @ 91.84 MPH Island Dragway Great Meadows NJ Summer 2009.
ErnieR
