Does anyone know the shop manual-provided dimension of the reach-rod and valve assembly (overall)length for the 59-64 GT hawk power steering setup? I am putting this into a 53 coupe, and previously, on another '53 project, used the avanti dimension, but I suspect this isn't exactly correct. There is a specific length the reachrod/valve assembly achieves, after the rod is screwed into the female stub of the valve assembly , that the shop manual specifies , and should be adhered to, when putting it all together. The reach rod has one end that screws into the valve assy, the other goes onto the bellcrank, and there is a fair amount of play/leeway when it's put together, because of the threaded section on the rod. I would sure like to know the proper dimension, in inches, if anyone could check in the appropriate shop manual. If no one knows, then I certainly can purchase a reprint manual, but for one page, it seems a waste.... thanks- m. weiss
ok
ok
