Can a 1959 complete 2dr wagon body,be swapped over to a 1966 wagon frame and running gear. Without doing a lot of mods.
Frame and running gear swap
Ok, they look to be the same wheel bases, so they should be almost the same. But, I belive the 66 frame will also have a X member in it, like the convertables, I don't know if that would case a problem or not. I'm sure someone else will chime in that has more experiance in this though.
Dylan Wills
'61 lark deluxe 4 door wagonDylan Wills
Everett, Wa.
1961 Lark 4 door wagon
1914 Ford Model T
What engine are you going with from a 66? If its a 6 cylinder you may have some clearance issues with the radiator. On the 65 & 66 Studes the radiator support was slightly forward with a "cutout" section in the upper radiator panel. Other than that, you should be fine.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
The original 1966 v-8 more than likely upgraded to a 301ci. It was a sliding roof body, so i guess that means it would have the x-member and the flight-omatic. But i see no reason why that couldn't be modified to take a turbo-4hundredquote:Originally posted by Warren Webb
