See more
See less
Are These 11-Inch Brakes on My 51 Champion?
  • cbonner757
    Thanks for all the tips, guys. My 51 shop manual says the Champion came with 9/9 and Commander with 11/9, so what kind of car and year would 10-inch drums be, so I can look for parts?
    Regards,
    Clarence
  • candbstudebakers
    how many do you want Nate??
    Castro Valley, CA
    canbstudebakers-
  • gordr
    Agree with alpayed; those are 10" front brakes, and those shoes MIGHT be available from your local jobber.
  • wayne
    I have the 11/9 on my 51 and it works fine. We have driven many miles in many conditions with good results.
  • 63t-cab
    Thanks Nate,I was just not sure if for some reason 11"/9" would be a BAD combo.
    Joseph R. Zeiger
  • N8N
    I wouldn't throw out any 11" brake stuff. Esp. drums that are still turnable, but backing plates are good to have too. Heck, I wouldn't mind an extra set of backing plates to clean up and detail "perfectly" - maybe have them powdercoated in anticipation of my next brake job
    The 11" is the nominal inside diameter of the drum, just so you know.
    11"/9" is theoretically front biased which is safe, but to get best braking you'd also swap to 10" V-8 rear brakes.
    55 Commander Starlight
  • starliner62
    Is anyone buying 11 inch cores? I have a few that I can get rid of. I dont need them since I have discs on my car.
    Jamie McLeod
    Hope Mills, NC
  • alpayed
    I am not familiar with 51 Champion brake sizes but the brake drums in Clarence's post are 10". The drums are measured inside diameter.
    So 10" front and 9" rears should be appropriate.
    Putting 11" drums on the front with 9" original rears will shift a greater proportion of the breaking effort to the front.
    If you do it you will have to increase the wheel cylinder size on the rear to put bias back to the rear wheels.
    It is better to stick to the original 10/9 or 11/10 configuration.
    Allan.
  • 63t-cab
    This post has me wondering if it is simply ok to have 11" in front with 9" in rear? or should it be the normal 10"/9" or 11"/10"?
    Joseph R. Zeiger
  • cbonner757
    Great, thanks, Matthew and Rockne. I wouldn't try relining them myself. But knowing what year and style to order was essential to getting the right parts. Do you have contact info for Chuck Collins? I've dealt with several vendors but am not familiar with him. When I get the front finished, I'll do the rear. Anyone know if the previous forum posts are accurate that 73-78 Cougar, 71-79 Dodge pickup, or 49-71 Ford pickup wheel cylinders interchange for the 7/8' bore wheel cylinders used on the back brakes?
    I hope things are going well in Hazlehurst-- I grew up near Conyers but have lived all over the planet since, and am in Virginia Beach now. I'm headed to Conyers the end of the month to visit my dad.
    Regards,
    Clarence
  • rockne10
    If you don't have the equipment to reline them yourself, several Stude vendors will reline them for you. Dave Thiebeault did mine. SI also offers relining on your cores.
  • mbstude
    Someone has upgraded to the 54-66 V8 brakes. We recently did the same to our 51 Champion. MUCH better braking than the originals. [^]
    The only place to get shoes is from the Stude vendors, Wagner or nobody else carries them anymore. I bought a new (not relined) set from Chuck Collins just a couple of weeks ago and I have nothing but good to say about 'em.
    Matthew Burnette
    Hazlehurst, GA
  • cbonner757
    started a topic Are These 11-Inch Brakes on My 51 Champion?
    My 51 Champion has 9-inch brakes on the rear, with the typical eccentric style adjustment.
    The front ones appear to be the same as my 62 Lark I had 20 years ago. But my memory from a car I had 20 years ago is fuzzy. Is the 11-inches measured inside or outside diameter? According my my measuring tape and how they are measured they may be 11-inch, except not finned.
    Any idea what kind of car they came from, if they are not finned? 51 Commander? Special order on the Champion? I need to know, 'cause baby needs a new pair of shoes...
    Regards,
    Clarence
    Album showing what it looks like:
    http://s827.photobucket.com/albums/zz199/cbonner757/
