generator to alternator
  • generator to alternator
    To convert a 62 Lark from generator to alternator, can the in place wires be used? If so which wire is left out? Field, Arm, or Ground?
    Which is which?
    David G. Nittler
    David G. Nittler
    Which alternator would you be using?
    Bellingham, WA
    Bellingham, WA
      Not sure I gave the car to my son.
      David G. Nittler
      David G. Nittler
        There are a variety of alternators that would work or that could be made to work. Each would wire differently.
        Bellingham, WA
        Bellingham, WA
          you can use a one wire gm alternator and eliminate most wires and just run one wire to the battery terminal.
            http://www.madelectrical.com/electri...hreewire.shtml
            Good information on 1 wire vs. 3 wire.
            3E38
            4E2
            4E28
            5E13
            7E7
            8E7
            8E12
            8E28
            59 Lark
            etc
              As to wiring the one wire gm alternator I've been told you can wire it the voltage regulator on the Battery terminal.
                CONTACT MAD ENTERPRISES AT WWW.MADELECTRICAL.COM
                I JUST DID THE CONVERSION ON MY HAWK ,
                THIS GUY HAS ALL THE INFO
                HE HAS THE WIRING AND SPECS AND WHAT AFTER MARKET ALTERNATOR PARTS YOU WILL NEED TO BUY
