64 Daytona electrical problem (previously carb)
  • #16
    The earlier Delco is just as good as the window - it's also alot more plentiful and cheaper. Most window Delcos for Studes go for $100+
    1963 Cruiser
    1957 President two door
    • #17
      I should have read Dick Steinkamps advice more closely. My guess is that maybe the mechanic that replaced the condensor and points did not lube the distributor, but that is only a guess. I will try to lube the distributor cam first. I saw where you can add oil on the distributor.
      1. What is the proper way to lube it?
      2. How often should it be lubed?
      If that doesn't work, I will look into ordering another distributor.
      Thanks again for all the great advice.
      • #18
        Also, if possible, let me know if there is a preferred weight oil to use.
        By the way Dick, you have a nice looking Studebaker.
