pinion gear
  • pinion gear
    Where does one find a pinion gear for a silver hawk? I think it's # 537566. I've tried several vendors-no luck.
    If the pinion gear is broken, chances are you need a ring gear also. Try these guys...
    http://www.drivetrain.com/
    Bellingham, WA
    Bellingham, WA
      Sorry I was vague. It's the speedo pinion gear.
        There's a problem with what you're asking here. That part # (537566) is a pinion gear for a car fitted with the Studebaker (Detriot Gear) Automatic (1955 V8 and earlier car). A Silver Hawk wouldn't have such a tranny unless someone had gone to the trouble to transplant one into it.
        Miscreant adrift in
        the BerStuda Triangle
          I think most of the major vendors have them. You will need to know the rear end ratio as that determines both the pinion and speedometer gear part numbers.
          Museum R-4 engine
            Here's how I arrived at the part #. The car is a '57 Silver Hawk. The parts manual covers '55-'58.In the speedometer gear and pinion chart it lists model 16G8 (that's mine I think) with an axel ratio of3.31 (that's me again) with automatic requires a pinion gear # 537566. If I have calculated this incorectly please advise.
              Model 16G8 is for 55 president with V8, hence the wrong year -wrong tranny. Check the model codes at the front of the chassis manual. The listing is kinda hard to follow, took me a while to get it down.
              oops, as Mr. Biggs says Commander not President, I knew that.
              E. West
              "The Speedster Kid"
              Sunny Northern California
              Where the roads don't freeze over and the heat doesn't kill you.
              And an open road is yours to have -only during non-commute rush hours 9am-4pm and 7pm to 7am (Ha, ha, ha)
              Best Regards,
              Eric West
              "The Speedster Kid"
              55 Speedster "Lemon/Lime" (Beautiful)
              55 President State Sedan (Rusty original, but runs great and reliable)
                You need to look at your car's body tag. As the kid's said, 16G8 is a 55 Commander. Your car would be a 57H 57 indicating the year, "H" indicating a President-series car, or more to the point, a car with a 289cu.in. engine.
                Miscreant adrift in
