Rod Bearing Replacement
  • #16
    One way to tell if the bearings are responsible for your oil pressure problem is to accelerate briefly then let up on the throttle. Watch the oil pressure gauge. When you first step on it the pressure will drop briefly. When you let up on it the pressure will surge briefly.
    Back in the days when people were driving Studebakers just because they were such cheap transportation, people used to routinely abuse the engines (low on oil, never change oil, etc.). They were amazingly durable and could stand abuse for many thousands of miles. Many V-8s were scrapped simply because they were smoking due to bad valve guide seals. Years ago I swapped a R-1 (when you couldn't buy high enough octane gas for them) to JP who installed a '64 289 engine in my '64 Champ as part of the deal. The donor '64 Cruiser had 90,000 miles on it and had clearly been abused. I decided it would need an overhaul typical of the times (hone the cylinders, put in .001 rings and .001 bearings). I had a set of .001 bearings that I put in. I decided to plastigage them just to see how much worn the crank had been. Imagine my surprise when the plastigage was squashed out so far that I couldn't even read it (yes, I supported the crank to avoid the false reading that gravity can give you). I put in a set of standard bearing and plastigaged them too. They measured to the extreme tight end of factory specs. So, a 289 crank in an abused car essentially didn't show ANY wear in 90,000 miles. I'm convinced.
    Museum R-4 engine
    • #17
      I went into a Rambler 196 cu.in. a few years back. It had a knock when warm and it turned out that one rod bearing was the wrong size! All were standard save for this one that was .010 under. The gal that owned the car was driving it anyway (with the persistent knock[V]) as tho nothing was wrong! Drove it like this for weeks![:0]
      All it took was a new set of proper-sized bearings to quiet it down and the car now still motors on while the gal succumbed to cancer
      I don't know how much having a forged crank had to do with it, but in spite of the gross clearance it had run with, the journal looked and measured like new![^]
      Miscreant adrift in
      the BerStuda Triangle
      • #18
        A .010 under bearing would just lock up a stock crank. Maybe the crank was turned .020 ?
        JDP
        Arnold Md.
        Studebaker On The Net
        http://stude.com
        My Ebay Items
        http://www.stude.com/EBAY/
        64 GT hawk
        64 Commander 2 dr.
        63 Avanti R1
        63 Daytona convert
        63 Lark 2 door
        63 Lark 2 door #2
        62 Daytona HT/ 4 speed
        62 Lark 2 door
        60 Hawk
        59 3E truck
        52 Starliner
        51 Commander
        JDP Maryland
