Latest on the Supercharged R1 Avanti
  • #16
    quote:Originally posted by edpjr
    The museum takes 4-5 weeks to process the production order. I'll post the results for interested parties just as soon as they're made available to me.
    I am still bitterly disappointed that the motor was not a real R2. [^]
    I know I should not reply, but did the build sheet show the car was not a R2 when built ? I know the car now needs R2 heads to be "real", but every other R2 part was there and there is no such thing as a unique R2 block.
    JDP/Maryland
    "Proud owner of a Lark powered Avanti"
    Thanks.
    JDP/Maryland
    JDP Maryland
    • #17
      IIRC you have R1 heads with the R-series pistons? that should be somewhere between 10:1 and 10.25:1 depending on your head gasket thickness (not 13:1) should not be a problem so long as you are running the best gas you can find (and you should be anyway with any R-motor) are in good tune and don't have the whirly thing engaged. Might even run OK with the blower engaged so long as you're not trying to embarrass any Supra owners.
      • #18
        It definitely has the orange whirly thing engaged and operating. I went by to drop off the new brass PCV valve to my brother John tonite, so I drove the Avanti down the road. It runs real good and will bark a tire if you manually shift it from 1st to 2nd. John retarded the timing a bit and I'm using 100 octane fuel plus octane boost, so there's no spark knock either. I'm generally happy with the car's performance for now. I never expected 0-60 mph acceleration in 4.9 seconds like my '07 Vette will produce. [8D]
        edp/NC
        \'63 Avanti
        \'66 Commander
        • #19
          well if you're running race gas, 10:1 squeeze and a blower, I BET it barks the tires! If you don't mind the fuel bill maybe you should just leave it that way...? You probably *need* the electronic ignition to light that off reliably but you already have it covered.
