Transmission Number
  • Transmission Number
    On my 3 speed Overdrive where is the I.D number so I can verify the year. My car is a 51` but my motor is a 62` 259. thanks
    Cast in the side of the case, i.e. T-86
    JDP
    Arnold Md.
    Studebaker On The Net
    http://stude.com
    My Ebay Items
    http://www.stude.com/EBAY/
    64 GT hawk
    64 Commander 2 dr.
    63 Avanti R1
    63 Daytona convert
    63 Lark 2 door
    63 Lark 2 door #2
    62 Lark 2 door
    60 Hawk
    59 3E truck
    52 Starliner
    51 Commander
    JDP Maryland
      Cast # T86E-1A
      Stamped # K41-3
        JDP
        Arnold Md.
        http://stude.com
        My Ebay Items
        64 GT hawk
        64 Commander 2 dr.
        63 Avanti R1
        63 Daytona convert
        63 Lark 2 door
        63 Lark 2 door #2
        62 Lark 2 door
        60 Hawk
        59 3E truck
        52 Starliner
        51 Commander
        JDP Maryland
          I went back out in the garage and looked and the stamped # is K41-3. It`s not a slide in, and it is a short tail. Thanks
            Looks to me like October 4th, 1951, 3rd shift:
            http://home.comcast.net/~jdwain/trans.date.jpg
            [img] http://home.comcast.net/~jdwain/63.63.jpg [/img]
            Dwain G.
              Thanks for the info. Dwain G.
              Does anyone have any info. on the rear end.
                Well; we can't tell you what you have, since it's a home-built car. But I can tell you what it COULD be, and where to look to verify it.
                On the back side of the diff. housing, lower right side there is a web between the "pumpkin" and the axle tube. On that there should be a raised # in the casting. It should be a "44", if this '51 is a Commander but could be a "23", or "27" they are all Dana/Spicer tapered axle rear ends, the later are for lightweight low powered cars. The ratio should stamped be on a tin tag under a bolt on the rear cover, usually at about 7 or 8:00 (under left lower bolt).
                Studebakers Northwest
                Ferndale, WA
                  On the rear end The cast# is 2018 188. On the tin tag # is W 50-11.
                  Rob
                    50-11, 50 divided by 11 equals 4.5454. That's usually called 4.54 or 4.55, makes a 232 pretty quick, runs a larger engine too fast.
                    Tom Bredehoft
                    '53 Commander Coupe
                    '60 Lark VI
                    '05 Legacy Ltd Wagon
                      My `51 Commander has a `62 259. I plan on building it up some. It should be a pretty quick car to cruise around town in, with 4.55 gears
                      Is this a Dana 44
                      Rob
                        Is this a Dana 44
                        Can't tell until you post the answer to Rich's question...
                        "Well; we can't tell you what you have, since it's a home-built car. But I can tell you what it COULD be, and where to look to verify it.
                        Bellingham, WA
                        Bellingham, WA
                          It is a `51 Commander The cast# that I found on the rear end is 2018 188.
                          Rob
                            There will be a 44, a 23, or a 27 in the web between the right axle and the pumpkin. This will tell which Dana rear end it is...
                            Bellingham, WA
                            Bellingham, WA
                              Thanks , I`ll go out to the garage and check.
                              It`s a 44.
                              This is a great site for Stude info. Thanks guys
                              Rob
