Auto Trans Swap - long and short shaft
  • Auto Trans Swap - long and short shaft
    Good day,
    I have a 57 Silver Hawk finishing up. It has the stock Auto Borg Warner. I have a 2nd transmission - same type but freshly rebuilt which I am buying - - same but from an Avanti and has the long nose.
    Would it be better to swap out the nose housings assuming it's possible or do I need to go from a split drive shaft to a single unit?
    Also this tranny doesnt have the fill cap but the boss where it could be drilled. Hummm?
    Thanks for any help on this issue!
    Ches in SD
    Just wanting to drive my Stude in the black hills.
    quote:Originally posted by HammondA100
    Good day,
    Ches in SD
    I'd use the long tail shaft and a late drive shaft. The fill tube goes into the trans pan on late transmissions.
    JDP Maryland
      And if it's really a Powershift from an Avanti, the shift pattern on this transmission will not match up with your original auto shift pattern. Avanti pattern is PRND21.
      Paul
      Winston-Salem, NC
      Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.com
      Paul
      Winston-Salem, NC
        "I'd use the long tail shaft and a late drive shaft. The fill tube goes into the trans pan on late transmissions."
        Ugh - That's what I was afraid of. Sounds great but that option requires me to hunt down another part. But if the solid single drive shaft eliminates problems and doubt - I will go that route. THanks for the assistance.
          There may be other hinderances to address here - like floorboard clearance. Also, if you do go with the late transmission, look for a one-piece shaft that'll work in concert with whatever rear axle you have in your '57. It could be a type 27 or a 44 rear and that makes a difference in length.
          1963 Cruiser
          1957 President two door
            That's the advice I need. Thanks for the tips.
            I only feel dumb for not looking under a few later models at this while at Cedar Rapids.
            I must ask though - any isues if I just switch out the nose or horn on the back of the transmission? Which would allow me to keep the shaft installed now?
            It's a Dana 44.
              It's a Dana 44.
              A close review of the parts manuals for your two transmssions may give you the answer to whether you can swap the output housings.
              Paul
              Winston-Salem, NC
              Paul
              Winston-Salem, NC
                One of the issues will be having to totally disassemble the Trans. to remove the short output shaft and all of it's components, speedo drive gear, governor etc. and replace with the long tail type.
                Another issue is, you will need to add a Trans. Cooler in front of the radiator, flex lines and metal cooler lines.
                The best setup for the shift linkage would be to install a '63-'64 Hawk Power Shift (floor shifter assy., tower, boot and plate.
                Looks like you might have gotten a bit trigger happy, but it is all fixable! [^]
