47 champ shift rod stuck my shop manual only tell how to ajust it not how to get it off the steering collum. You know the three in the tree. can some body help. when I crawl under and shift the trans is fine. the control box on the collum is stuck and the shift handle will mot move
shift control box stuck
We're not sure what you mean by 'stuck'. is it stuck in two gears and won't go, is it stuck in first gear and won't get out? We need more details.
Tom Bredehoft
(Under Construction 617 hrs.)
'05 Legacy Ltd Wagon
All Indiana built cars
It is possible for the motor mounds to sag to the point that the shift linkage does not operate properly. Oil saturation of the motor mounts might cause this, also. Next look at the linkage, and the bushings around the linkage. Basically, look at the easy stuff first, before you tear into the steering column.
Paul Johnson, Wild and Wonderful West Virginia. '64 Daytona Wagonaire, '64 Daytona convertible, '53 Commander Starliner, Museum R-4 engine, '62 Gravely Model L, '72 Gravely Model 430
