Brakes lights I assume don't work 55 president
  • Brakes lights I assume don't work 55 president
    After I put a board on the brake pedal, and the lights don't go on after 20 some years, I think first check bulbs. But then I 'll have to trace down the fuse , and hydralic switch, right ? thanks Mike 14x7
    If it has been sitting that long, you could very well have "grounding" problems. Since all these cars used a chassis ground, you could have rust and corrosion at the grounds on every light socket in the car. Since the brake light is a "Pressure" switch, you will have to have enough "Pressure" to activate it. Once you have made certain that you have good ground on your circuits, good bulbs, and a "hot" wire going to your brake switch...then you can check to see if the switch is good by applying enough brake pressure to the system. A board might not be sufficient if the pressure does not "hold" sufficient pressure to activate the switch. Either get a helper to observe as you press the pedal or do it after dark so you can see the lights as they activate.
      So if I understand that correctly the lights wont come on unless the brakes are actually working and holding pressure no matter how far down the pedal goes,correct? Steve
        Yes
        Skip Lackie
        Washington DC
        Skip Lackie
          Thanks Skip. Steve
