I am restoring a 1960 lark and i am having trouble with brake light operation. Where is the brake light switch or sending unit.
brake lights/electronics
Look down over the drivers side inner fender. There should be a brass distributor bolted to the frame, where the system splits to the front and rear wheels. OR
Look under the drivers side floor pan where the Master Cylinder is located. Follow the output line.... You'll find it
Bob Johnstone
www.studebaker-info.org
64 GT Hawk
55 President State Sedan
70 Avanti (R3)64 GT Hawk (K7)
1970 Avanti (R3)
Depending on the nature of the problem it should be noted, the brake lights are wired through the turn signal switch. Often, the problem is there.Brad Johnson,
'56 Sky Hawk in process
