Last night I talked to Bob Powell, a retired Stewart Warner engineer that still works on gauges. I had hoped that Bob could look at my gauge and sending unit and get them to work properly (still reads 5/8 to 3/4 when I have a full tank). It was clear Bob's memory was not what it used to be, but two things were clear: 1) He cannot fix Studebaker gas gauges any longer due to not having the right parts. 2) Studebaker did not use a standard 30 to 240 ohm sending unit! I challenged Bob on this but he was certain this was the case, he even used the word "weird" to describe the Studebaker sender (and these were made by S/W so I am guessing he should know). Bob could not remember what the range on a stock Studebaker sender should be, too bad. Anyway, this is probably the reason many of us cannot get a full reading when the tank is full. I would love to know if any one has a NOS or good used sending unit they could actually measure the range of resistance to let us know what it is.
What I have found is that you can "force" the gauge to read full if you bend the float stop and allow the wiper arm to ground out on the sender body. This however is a false reading and will drop to 5/8 to 3/4 the instant that the level drops enough to let the float move off the stop.
If you are going to buy a new sender from SI or other suppliers you will find the new units are not wire wound any longer but use a ceramic thick film and you cannot force the sender to cheat and give a false full reading. These new units are 30 to 240 ohm std. S/W sending units.
I plan to send my gauge and sender to a rebuilder to match the two to get the right readings. However, it now looks like that will be the only solution unless you can find a NOS sending unit.
Dan White
64 R1 GT
64 R2 GT
Dan White
64 R1 GT
64 R2 GT
