i know i have either a 259 or 289 but do not know which can someone help engine id= jk633
64 commander
On the front of your engine, just on the driver's side and forward of the oil fill pipe is a machined pad. Stamped into this pad is combination of letters and numbers. Post them here. Someone will interpret it for you.
[Edit] mea culpa, I didn't read far enough before posting, I guess.
Tom Bredehoft
(Under Construction 617 hrs.)
'05 Legacy Ltd Wagon
All Indiana built cars
OR, look it up right here in the Tech tips and Spec's and data link on the home page of this website:
It looks like a 1964 date coded engine number, but are you real sure that is correct, something does not match up here. [:0]
The 6 and the J could not be right. The first letter should be a "V" or "P". If it were a J, it would have to have a T or TS following it and then another Letter before the numbers. [:0] [?]
The other way to I.D it is:
(1) check in a spark plug hole for a dished piston, you can see it with a light when one is up, or feel it with a pencil, indicating a Std. non-jet thrust 289.
If it has flat top pistons, it is MOST LIKELY a 259.
(2) look for an oil filter base or mounting pad on the right side, rear of the block, telling us it IS a late '62-'64 block.
StudeRichStudeRich
1964 model year 259 cubic inch displacement.quote:Originally posted by gc6969
im sorry vk633
Studebaker enthusiast much longerGary L.
