Repairing a Clutch Shaft Sleeve
  • Repairing a Clutch Shaft Sleeve
    I am getting ready to install the engine back in my '63 R2 Lark, and noticed that the sleeve (part #199220)which joins the two halves of the clutch shaft is shot - there is no longer a postive connection. I know this is a common weak link on Studes, but I am curious how others have repaired it. I did a search, as well as recalling some old Turning Wheels articles, and thus know some people advise welding the shaft to the sleeve. Is this the best approach? I understand it would be stronger, but I wonder if it being rigid is the right option. I see the part is still available, but before I decide a path, I wanted to get some of your expert opinions.
    Thanks!
    Eric DeRosa
    '49 2R-5 (original Survivor)
    '63 R2 Lark (barely surviving)
    Eric DeRosa
    \'63 R2 Lark
    \'60 Lark Convertible
    There should be [u]no</u> reason to weld the shaft(s) to the sleeve p/n 199220. The sleeve connects the clutch linkage components together with two pins. The pins provide the "solid connection".
    While SASCO does not list the sleeve, it is a common item used on Studes for years. Several of our vendors should have these. Check with Sudebaker International, Chuck at studebakerparts.com, Bob Kapetyen, etc.
    Paul
    Winston-Salem, NC
    Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.com
    Paul
    Winston-Salem, NC
      What *should* be welded is the bellcrank. I wonder if the sleeve is the same size as a double-D steering coupler? Anyone got one laying around to try? Sure could be a little beefier, for those guys running stronger-than-stock pressure plates.
        What should be welded is the "fingers" that contact the throw-out bearing. They are splined and weakly copper brazed to the cross shaft. Many times they will slip their splines and fail to engage the throw-out bearing fully. The result will be an annoying clutch pedal that won't keep adjustment.
        While things are apart, there is a bronze bushing in the bellhousing,(that the end of the cross shaft rides in) that can be replaced.
        A good bearing store or NAPA should be able to match it up.
        Bez Auto Alchemy
        573-242-3530
        Blogger is a blog publishing tool from Google for easily sharing your thoughts with the world. Blogger makes it simple to post text, photos and video onto your personal or team blog.
        Bez Auto Alchemy
          Bez Auto Alchemy
          573-242-3530
          Bez Auto Alchemy
            I got a complete clutch linkage setup off a 63 Lark V8.I would be willing to sell it all .If you are interested PM me.Thanks ChampTrucking@hotmail.com
              The trucks have a heavy duty sleeve (683833). I put one on my R 2 several years ago and with a heavy duty clutch, it is still holding. I think I bought an extra one and will look for it if you want me to send it to you.
              Ted
              Thanks!
              Eric DeRosa
                Ted, is the 683833 the same size (internally) as the stock car one? If so I might just order a couple myself, for insurance.
                  I can't say I measured them but it went on the Tomato with no problem. You can see looking at it, it is heavier made than the standard one.
                  Ted
